https://youtu.be/9Mpe2lcKTak
Hu101 cutting
Tried with a b111 just to see if edge cut pulls more power somehow
But still about 70watts
https://youtu.be/2HIOo_JBa0U
Hu101 cutting
jodge (10th September, 2018)
thx i will share my idea after my machine and the other stuffs are arrived tested..etc
To Samic
Attached the customkey file i made .
Cutting code is 23434313.
Because off my blade width it does not seem that the machine takes it in consideration ..
Because also this is a B-Cut key i cannot play around with the custom keytool file setup to let my more narrow keyblade blanks work correctly .
On the megane2 blade that is A side cut it was far easier to make a custom keyfile so that all the different size blades i had worked perfectly on the locks.
Ok played around with the universal key decode and cut and managed to lift the worn key up high enough so that it trace and cut .
But machine stops when i press button to cut the new key .
I think this is because it traces the internal width off the cut to be 250 and then it picks it up to be outside the minimum allowed parameter off 330 ..
Pierre
Which is the latest stable version for KM03 Europe ?
Anyone know if condor mini can cut SMART CAR VA2/VA6 Key?If Yes please share how to do it.
I have chosen VA2 but we need to use TOYOTA CITROEN or PEUGEOT because SMART is not listed so I was trying with peugeot and citroen but key wont turn.
Measure the org key like this,
Try Toyota avensis and the latest model and it’s there
When will they add the new hu101 internal found on the latest ford fiesta?
IC 1423 is on instacode app and says can cut from condor so must be there, the avensis one might only be 6 cut
The ford is IC 1434 don’t xhorse have a tie in with instacode, hopefully add it soon
