Page 93 of 127 FirstFirst ... 43838889909192939495969798103 ... LastLast
Results 1,381 to 1,395 of 1900
  1. #1381
    Wegrow, Poland
    Condor KM02, software 5.1.9. Condor broked 1.5mm cutter when going from left side to right side YM15 key. Mercedes Sprinter.
    See https://youtu.be/RHKMVxIxyXA
  2. #1382
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by fabi View Post
    yeah it's a well know problem they don't fix like the GT15, live with it
  3. #1383
    RG550's Avatar
    Oct 2017
    Quote Originally Posted by jodge View Post
    GT15 also broke cutter like YM15 ?
  4. #1384
    Cut left side of key. Stop cutting, flip key and cut left side again and remove before it moves to right side
    Sent from my SM-G960W using Tapatalk
  5. The Following User Says Thank You to dmp For This Useful Post:
    RG550 (17th September, 2019)
  6. #1385
    Wegrow, Poland
    HU72R broke cutter like YM15
  7. #1386
    Jan 2017
    USA ����
    Quote Originally Posted by dmp View Post
    it calibrates on the key on both sides so.........
    wont it cut wrong?
    for the second time
  8. The Following User Says Thank You to sleepyrz For This Useful Post:
    RG550 (20th September, 2019)
  9. #1387
    Jul 2015
    Quote Originally Posted by sleepyrz View Post
    wont it cut wrong?
    for the second time
    I think so. You have to pull back the key until the cutter passes the center line of the key.
  10. #1388
    Jun 2013
    Dolph - HU66 - Q7 style.
    Update to latest update before cutting.
    Smallest cutter mounted. I think it is 1,5mm?
    Result:
    - Open door - Yes
    - Ignition - NO
    Cut again with A9, which widens the cut all over - Result - everything is OK.
    This one needs fix. Extra time wasted.
    Maybe it would be OK with the largest cutter. But did not test.
  11. #1389
    Jan 2017
    USA ����
    Quote Originally Posted by gokart View Post
    Yea thats pretty much what i do
    Or if i dont want to risk losing a finger......
    Just cut one side then use duplicator to cut another key
  12. #1390
    Jan 2017
    USA ����
    Quote Originally Posted by PerryZhang View Post
    YM15 ,what is problem of this ?
    It doesnt work.....
    Try one
    It will cut one side of the key just fine and then as it goes over to the second side to cut it
    it cuts off the tip of the key or breaks the cutter or rips the key from the Jaw
    It has been like this since day 1 with old condor master 007 machine in 2013
    Then you make condor xc-mini
    It still has this problem
    Then you make condor xc-mini km03
    Now we have condor xc-mini plus
    Now you just released Condor XC Mini Plus 2 and battery powered dolphin
    It still has this problem both of them
    From day 1 this machine has problems that never got fixed
    6 machines later and almost 7 YEARS
    You still cant cut simple key??????????
  13. The Following 2 Users Say Thank You to sleepyrz For This Useful Post:
    paul_12345 (20th September, 2019), RG550 (20th September, 2019)
  14. #1391
    Wegrow, Poland
    It doesnt work.....
    Try one
    HU72R too
    See video:
  15. #1392
    RG550's Avatar
    Oct 2017
    It doesnt work.....
    Try one
    You are absolutely right, "sirius" company...FIX F.... simply key cutting...what to say about VA2, VA6 etc...
  16. #1393
    kronk92's Avatar
    Sep 2016
    France, paris
    i struggled recently on a va2 for peugeot 107, the decode is wrong but i know this problem is old so input the bittings manually but it cutted it wrong, in the last updates it was cutting ok now no, i wasted so much time and blades, sadly you can't rely on these machines, one update it cuts good the next update no, it is a real mess
  17. #1394
    Junior Member dedz's Avatar
    Sep 2016
    Hello nay news for cut megane 3 laguna 3 clii 4?
    Envoyé de mon SM-G965F en utilisant Tapatalk
  18. #1395
    Jun 2013
    Quote Originally Posted by kronk92 View Post
    Yes this right. You need also a machine from a different brand, just to be sure to make the job. Updates sometimes good, sometimes not. But needs to keep reporting, so the bugs can be removed fast as possible.
