the side cuts is to small
this is the key i cut with mini.
for working need be like this
same with Ford Tibbe F021 key M8 ....
Machine makes a hell off a humming noise after last cut and jams into the tool ....
So i make cutting first side till it is completed.
Stop the machine ..
Then turn the key around.
Restart cutting from beginning . So not to damage my machine...
If need to fix this you will have cut away back part off tool holder till there is nothing left on it
(Interesting that demo video only shows first side off key being cut)
I have return to 3.0.1.work ok on fo21
Στάλθηκε από το F3311 μου χρησιμοποιώντας Tapatalk
Unfortunately can't do key file Because pc program not support this type of key. The side cuts is 3 different deep.
Which version do you see here (top of the screen): http://www.digital-kaos.co.uk/forums...3&d=1501125653
When the demo was made the sw version was 3.0.1. It worked great.
@Kleidaras can we have a look of your code input?
@PierreTheron@Sleepyrz can you send me some files to check this problem?
@Louis21 you want picture for machine display?
Ok made update on my machine and problem with F021 key seems solved .<br><br>parameter info was 1.08 before ..update ..
Great,so how about sleepyrz's?he has this problem too?@sleepyrz
@Kleidaras yes,the sreen display,that you input the bitting numbers 1 2 3 into,and so on,that interface.your side bitting input 2 2 1 1?
i will try aand see
