Could it be dependent on the setting so you could change if cutter checks key height or not?
Channel track key duplication problem with Condor KM03 v4.0.1, v1.13
how do i imput this BMW mechanical code into my condor -
read by autohex - 15693
Yeah some guys are very good figuring out the code by eye, is there a HU66 Diagram I can reference, or put over the key to figure out the code,
You have a perfect way of doing it, yes I did not really know how to machine figures out the points I always thought it was by pressure, guess its a mixture of a bunch of things....
Learn something new every day,
Jobeso66 (10th November, 2017)
Instacode is helpfull.
You can even display a key, after typing in the cuts.
Hu66 reading tips: look at the bottom first.
There you will look for the cut height. 1.
And look at the upperside, and look for 4 cuts.
Compare every cut to the cut next to it.
A 1 depth will not be next to a 4 depth.
So compare every cut, with the cut beside it.
Any USA or Canadian Seller for this condor machine? Please PM me.
american key supply
The Renault Megan key "V' opening cutting incorrect is revised,please update condor(V4.0.1)and check.Please give me feedback after you have a chance to cut one
gokart (13th November, 2017)
Megane blade is not ok
Στάλθηκε από το F3311 μου χρησιμοποιώντας Tapatalk
I get the feeling this blade is the only problem of the Condor. It is in the discussion ever since the first Condor XC007 was released. It has never been OK. For years it has had the same issue - Condor just can't cut this!
I do this with my manual machine before i use mini and problem solved.
