Page 7 of 127 FirstFirst ... 234567891011121757107 ... LastLast
Results 91 to 105 of 1900
  1. #91
    Jan 2016
    I have down loaded the link just seems to open in my winraw then just opens into folders can you advise on what to do please .
    How do i get the drivers set up and open the program ?
  2. #92
    rob h's Avatar
    May 2011
    http://blog.xhorsevvdi.com/how-to-up...-cutting-tool/
    Quote Originally Posted by Romney1 View Post
  3. The Following User Says Thank You to rob h For This Useful Post:
    Nassreddine84 (18th December, 2016)
  4. #93
    Jan 2016
    I have connected the condor turned it on but how do I run the drivers like stated in step two ? if I click on custom tool in update section it opens up but I cant seem to sync or update my machine . do I need do anything with the driver folder in the download . this is stressing me out :c please help
  5. #94
    rob h's Avatar
    May 2011
    Make sure that you have internet connection.
    If needed, turn of virus scan and firewall.
    Run program as administrator.
    Turn on Condor.
    Connect usb.
    Press Synchronize.
    This will activate the Condor.
    Then press update,
    Then update online,
    Or choose update ofline, and load the v2.3.3 file from your computer.
    The update will take about 20 minutes.
  6. #95
    Jan 2016
    Thanks managed it on the desk top , one of the updates was for the blank i need to cut hu56r u had any joy cutting these with the machine running the 2.3.3 ?
    kind regards
  7. #96
    Jan 2016
    Hi just to check should my machine say v.2.3.3 in the right hand corner of the screen of 2.3.3 beta ? Only updater just listed 2.3.3 not beta ?
  8. #97
    rob h's Avatar
    May 2011
    In the screen, V2.3.3
  9. The Following User Says Thank You to rob h For This Useful Post:
    Romney1 (18th December, 2016)
  10. #98
    Jan 2016
    Has anyone had any joy cutting key blank HU56 volvo / Mitsubishi when running v.2.3.3 ?? Only just updated my machine but previously on v2.2.9 had no luck , thank you in advance
  11. #99
    siyadk's Avatar
    Dec 2012
    I am still stuck in v 2.1.2 for ages. Condor xc mini update software shows v2.1.2 as latest one. Yes i know there is offline updates available but why is it not available in software. screenshot attached
    SAMIC, PLEASE MAKE ALL UPDATES AVAILABLE IN SOFTWARE
  12. #100
    rob h's Avatar
    May 2011
    If you go online, you can update the latest.
    Press the update online. Or update offline.
    Use the file that i posted.
    Click on the menu next to the update online.
    Select there, update offline.
  13. #101
    siyadk's Avatar
    Dec 2012
    Rob H,
    Are you using the mini or the old condor xc007? i believe these updates are for the old and big condor xc007. i have is the mini. Unfortunately i havent seen any update on mini for a while now
    Quote Originally Posted by rob h View Post
  14. #102
    Moderator
    PremierD's Avatar
    Jun 2009
    3.0.1 is the latest ... i think
  15. #103
    rob h's Avatar
    May 2011
    This for the 007 master.
    Not the mini.
    The way it updates online, is the same.
    Only difference is the sw. Witch is autodetected online!
  16. #104
    siyadk's Avatar
    Dec 2012
    as far as the mini is concerned, it is v2.1.2
    i wonder no updates on mini
    @premierD , do you own mini or bigger one
  17. #105
    Dec 2015
    Yes @siyadk u r right i also own mini and the latest update is the v2.1.2 i confirmed with the dealer as well and he said the same as for 3.0 this depends on the serial number there is 2 versions of mini KM02 and KM03 so 2.1.2 is same as 3.1.3 its the serial number and manufacture code no any difference
    NO ADVERTISING PLEASE
  18. The Following 2 Users Say Thank You to Nassreddine84 For This Useful Post:
    kleidaras (21st December, 2016), siyadk (21st December, 2016)
