Page 99 of 127 FirstFirst ... 4989949596979899100101102103104109 ... LastLast
Results 1,471 to 1,485 of 1900
  1. #1471
    auto techniek's Avatar
    Mar 2017
    Can someone decode pls.chevrolet spark. I think DWO4 blade.
  2. #1472
    Jan 2017
    USA ����
    it doesn't matter at all you can use whatever cutter you want i was using the 2.5 mm cutter for everything for years and all the keys work just fine I switched over to the 2mm cutter though and the keys are a little smoother entering and leaving the lock now
    I cut every single key with a 2 mm cutter now
  3. The Following 4 Users Say Thank You to sleepyrz For This Useful Post:
    autoTkey (27th November, 2019), cklair (27th December, 2019), sdnatlst (26th November, 2019), Weasel3 (2nd December, 2019)
  4. #1473
    sdnatlst's Avatar
    Aug 2011
    England
    hahaa i have been switching blade every time i go from channel track to side cut profile blades,,, thanks for letting me know, save me some time
    Tools owned -
  5. #1474
    Dec 2018
    Quote Originally Posted by gokart View Post
    HU56 is OK on KM03.
    What is KM03?
  6. #1475
    Dec 2018
    Quote Originally Posted by autoTkey View Post
    1.5mm is used very rarely. Most keys are best cut with 2.5mm. So use 2.5mm and most poblems go away.
    Whith hu64 it says often times use 1,5.... and you can always use 1.5 with hu66 and others without problems.... A colleague alsway use 1.5.
  7. #1476
    Feb 2014
    Quote Originally Posted by Alpaholic View Post
    No, it just shows you what cutter you have set in settings. 1.5 is needed only on very few keys. Machine gives specific warning when this is the case. Use 2.5 or 2 as suggested here in the forum for best results. I always use 2.5 and key works like it has been a part of the lock - no tension or any sign of excessive friction.
  8. The Following User Says Thank You to autoTkey For This Useful Post:
    Alpaholic (29th November, 2019)
  9. #1477
    Jan 2017
    USA ����
    I noticed on some close spacing edge cuts like toyota 10 cut or nissan 10 cut its a little too steep the cuts and with 2mm it goes in and comes out smoother
    don't get me wrong 2.5mm still works fine and turn the lock perfectly but entering and leaving the lock is just a wee bit smoother with 2mm
  10. The Following User Says Thank You to sleepyrz For This Useful Post:
    autoTkey (28th November, 2019)
  11. #1478
    Hi guys. need help. I need to make a key blade pattern from the key code on hyunday tucson 2016 usa. mechanical key code M2227. key blade HY22 or TOY40.
    the ignition lock has 6 secrets. in PM. thanks
  12. #1479
    Jul 2018
    CHINA
    the new hyundai key ? that one , you can try this option , search 'Kia ' 'K5' 'After 2016 ' , that one it could work for this , 8 bits
  13. #1480
    Jan 2017
    USA ����
    Quote Originally Posted by den5 View Post
    A223133
    B223123. Tip this way
  14. #1481
    Jan 2013
    hello i have oldsmobile cutlass 1982 with all key lost how to find biing code on door lock i have some code B2530 but i not find it in my condor can some one help me
  15. #1482
    Thank you PerryZhang, I already did as you said, problem solved.
  16. #1483
    Jan 2017
    USA ����
    Well first you need to know what the hell you are doing
    Second you need to buy yourself some reference materials like the Auto Smart books or the fast facts books
    Theres no code on the door lock genius
    You just wasted a lot of your time with this
    Get the books and learn or continue wasting your time
    Your choice.......
  17. The Following User Says Thank You to sleepyrz For This Useful Post:
    fytfh (5th December, 2019)
  18. #1484
    can condor mini plus cut 2014 Toyota verso flip key...i think blade is va2?
    i have been given this code - 1DRB3
    not sure how to cut it/decode
  19. #1485
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by djollie View Post
    it's VA8 read back there will be a custom key file
  20. The Following User Says Thank You to jodge For This Useful Post:
    djollie (13th December, 2019)
