Quote Originally Posted by gokart View Post
It's a common VA2 for PSA. It isn't custom. I attached a high resolution photo. If you see that area what I mentioned in my previous post you can see two different curve.
1. straight line - it is the top layer (low depth)
2. correct curve - lower layer (high dept up to 1mm)
The straight line cut the top of the correct curve.
I am running your key cut in my condor mini. Same issue. It seems file is not accurate. I am afraid it needs to be corrected. See picture attached
