Page 32 of 127 FirstFirst ... 2227282930313233343536374282 ... LastLast
Results 466 to 480 of 1900
  1. #466
    Nov 2009
    Greece
    With 2.5 mm cutter VA2 VA6 is perfect
  2. #467
    May 2017
    @clientezar how about following this friend's suggetsion(with the 2.5mm)?problem solved or not?
  3. #468
    May 2013
    Hi there
    FO21 doesn't park the Machine correctly..... It cuts the key fine but the Cutter stays near the JAW after cutting.
    VA2.... I tried decoding and when it comes to the last bit it goes all the way left for about 2CM thereby snapping the DECODER tip.
    I didn't want to try it again on VA2 as I currently don't have extra decoders in stock to waste.
  4. #469
    May 2017
    About F021,what's your version of your parameter in the "Self-Test"?
    VA2:key decoded is not clean,when it touchs the thing non-conducting,broke
  5. #470
    Apr 2016
    Quote Originally Posted by louis21 View Post
    Not tried yet, will try tomorrow on test key...
  6. #471
    Sep 2017
    Quote Originally Posted by iHenry3 View Post
    My condor can't duplicate HU100 10cut, am I missing a update?
    I learned that I can trick my cóndor mini to cut HU100 10 cuts for Silverado and newer GM models First find out what is key code along with cuts. Enter your GM code select 10 cuts them manually input your 10 depths cuts.
  7. #472
    Mar 2016
    South Africa
    Hi does Condor have option for bmw motorcycle key BW9MH
  8. #473
    Sep 2017
    Quote Originally Posted by weza247 View Post
    Does Condor Mini have this function
    kia hy20 right hand blade
    Use HY18 for key on your picture , it will cut it the right way,
  9. #474
    Sep 2017
    If you have probably done it in the past , you have to input your bittins
    on cóndor mini backwards if you will where 1=5//2=4//3=3//4=2//&5=1 to be able to turn your plug in the cylinder
  10. #475
    Sep 2017
    Quote Originally Posted by sleepyrz View Post
    hy18 or hy18r
    type in cuts and see which one looks right i think they may be backwards in the machine
    Did you cut a working key HY18 on your cóndor mini? Mine did not, (ver4,,) As you know Depths for this key are (mm) 200 250 300 350 380. I cut several keys I realized these depths are off , I was using 1.5 • mm. After all I finally cut a working key but I changed settings to a 2.5• mm cutter (kept 1.5•mm bit on my spindle) , did you or anybody experienced this ??
  11. #476
    Sep 2017
    i guess you copied the key and didnt cut to code?
    why not use the code in the car????
    glovebox lock would have it.........
    It's your key physical dimensions, it happens to me. Go ahead File all 4 sides of your key , insert key on ignition then at same time push in and turn it clockwise. After this try it will learn it and cylinder will turn each time ( its crazy but it works)
  12. #477
    Jul 2015
    I had problem today with cutting VA2 for PSA. See the photo. I cut F C A A E A. The problem is at 1055-790. It mustn't be a straight line at the bottom.
    Condor mini KM03 cuts a straight line for the top layer then cuts correctly at the deeper layer. The cutting curve isn't the same for the 1 mm depth. It looks like a worn key after cutting. I ask the developers to check it.
  13. #478
    Sep 2017
    Gokart. Where the depths supposed to me measured from ? Left side of key or right side of key ? Is this a custom key?
  14. #479
    rob h's Avatar
    May 2011
    2-4-6 side A
    1-3-5 side B
  15. #480
    Jul 2015
    It's a common VA2 for PSA. It isn't custom. I attached a high resolution photo. If you see that area what I mentioned in my previous post you can see two different curve.
    1. straight line - it is the top layer (low depth)
    2. correct curve - lower layer (high dept up to 1mm)
    The straight line cut the top of the correct curve.
