>>>>>>>>>>>>>>CONDOR KEYCUTTERS <<<<<<<<<<<<<
Page 1 of 127 1234561151101 ... LastLast
Results 1 to 15 of 1900
    Moderator
    PremierD's Avatar
    Jun 2009
    Default >>>>>>>>>>>>>>CONDOR KEYCUTTERS <<<<<<<<<<<<<
    As the title suggests .. a new support thread for the above machines. same rules no talk about prices... all views welcome
  2. The Following 14 Users Say Thank You to PremierD For This Useful Post:
    aassfour (28th July, 2016), bram380 (27th August, 2016), CaioW (27th July, 2016), daxxer (29th July, 2016), jack44 (10th December, 2016), kevfield (27th July, 2016), milehighlockdoc (21st November, 2018), P&D (27th July, 2016), Samic (28th July, 2016), Siham (29th July, 2016), smokey08 (29th July, 2016), super jumbe (29th July, 2016), Tagne (27th July, 2016), tunertool (27th July, 2016)
  3. #2
    Apr 2015
    thanks for admin,if user have any technical issue or good advise about Condor machine please post here/PM me.
    latest update software for Condor XC-Mini KM02xx and KM03xx series is different,
    download link:
  4. The Following 11 Users Say Thank You to Samic For This Useful Post:
    AndyCZ (29th July, 2016), CaioW (30th July, 2016), daxxer (28th July, 2016), habbyb (1st November, 2019), InchisNonStop (23rd November, 2016), koyot (28th July, 2016), kyawkyaw (8th August, 2016), lush29 (8th August, 2016), mesut47 (4th June, 2017), Oxidoferroso (29th November, 2022), Tagne (28th July, 2016)
  5. #3
    Oct 2015
    Quote Originally Posted by Samic View Post
    Samic
    what is the difference between KM02xx and KM03xx series , i will buy mini condor in near future
    regards
  6. #4
    DK Veteran buga37's Avatar
    Apr 2010
    USA
  7. #5
    Feb 2014
    In case someone is having hard time using the search function of the forum, here are links to the old threads, should you need some old info:
    XC007:
    http://www.digital-kaos.co.uk/forums...ghlight=condor
    XC-MINI
  8. The Following User Says Thank You to autoTkey For This Useful Post:
  9. #6
    Apr 2015
    Quote Originally Posted by craino View Post
    Samic
    regards
    the difference are:
    motherboard,driver board,touch screen and add a fan near power.
    KM03xx will support Bluetooth function.
  10. The Following 5 Users Say Thank You to Samic For This Useful Post:
    autoTkey (29th July, 2016), daxxer (5th September, 2016), Hayssam1 (14th September, 2019), mesut47 (4th June, 2017), rm23 (29th July, 2016)
  11. #7
    Aug 2015
    Mars
    how we know is our machine is KM02 OR KM03?
    通过我的 T1-701ua 上的 Tapatalk发言
    IF I HELPED CLICK "THANKS"
    MVP pro,Tango, TMpro, SKP900, X100pro, i80pad, Mbtool, VVDI prog, KD900, Mini900, Ad900, Ts888, Ak500+, AK90, BMW Multitool, Xprog clone, miniprog, ETL, wellon vp380
  12. The Following User Says Thank You to haiz0708 For This Useful Post:
    JeligiGER (21st September, 2023)
  13. #8
    Moderator
    PremierD's Avatar
    Jun 2009
    Quote Originally Posted by haiz0708 View Post
    FFS ...."and add a fan near power."
    Have a butchers and see if there is one ..
  14. #9
    Apr 2015
    mate,turn on the machine you will find machine SN and software version in main-interface.
  15. #10
    May 2016
    has anybody had problems cutting hon66 with the lishi condor? i have cut 2 keys. one by code and the other by decoding original key and still no joy?
  16. The Following User Says Thank You to yammyman For This Useful Post:
    kleidaras (18th December, 2016)
  17. #11
    Apr 2016
    Quote Originally Posted by yammyman View Post
    Yes I had problems on a Civic.... There are two widthson these, I believe its the O type and the OL type,
    if it cuts the neck at the bottom (not the depth cuts but the actual neck where you have no authority)
    cuts too much (it wont work ) 02 Jazz fine... 06 CIVIC no good.
    now there are two types of HOn66 cuts available on the Condor (but they cut the same)
    Also VA2 - the Megane emergency blade,
    you need to add depth to this cut,
    I add about.35mm and then sometimes have to go back and add more otherwise the key wont fit.
    Am I happy with my condor... Yes very much so far.
    but you have to figure out the bugs (the update on mine helped a little)
    Yamy - are you Birmingham way
  18. #12
    lpf01's Avatar
    Oct 2013
    Mini KM03:
    Today tried to cut HU55P, cutter started to the other direction and cut into the jaw
    Countless lockpicking stuff, AVDI Original, Tango, Orange 5, TMpro2, sooo mutch chinese stuffs from FVDI Full through VCDS to Benz key programmers, 3 cats and hopefully still 20 fingers......
  19. #13
    Sep 2009
    Wegrow, Poland
    Bug in HU56 (Volvo). Condor cut clamp. http://www.digital-kaos.co.uk/forums...=1#post2742706
    MAZ24 no cut all bits.
  20. #14
    Apr 2015
    Quote Originally Posted by fabi View Post
    about Volvo HU56R condor machine database the key thickness is 3mm and cutting depth is 1.25mm
    but if fact,users key is different, thickness is 2.5mm and cutting depth is 1mm.
    so users can use define key data first,named 'HU56R-1_U',later we will find a better solution.
    1.connect PC to Condor machine
    2.use attached software,sync'HU56R-1_U' to condor machine
    3.select 'cut by bitting'---enter'HU56R'you will find HU56R-1_U,then cutting.
    other key issue still testing and fixing,if users find machine not work well/find bugs/good advise post here/PM me.
  21. #15
    Sep 2009
    Wegrow, Poland
    Hi Samic.
    Thanks for reply.
    Maybe can you add to firmware second position HU56R-2.5mm in next update?
    BR
    Fabi
