Anybody from xhorse here? I had a bad mother board on my condor xc mini and i finally got it replaced, i need it in english though, my serial number is KM03611722
Changed,please update it,then it will be English
jose9413 (26th July, 2017)
Does Condor Mini have this function
kia hy20 right hand blade
Jobeso66 (7th October, 2017)
Problem Megane II smartcard key. As you see in photo, middle key is original. Can you explain how to right cut? Also it read right the key Code. Attach images. Please help.
Enviado desde mi SM-G955F mediante Tapatalk
does it open the door??
No
No: they will not enter the lock.
No: they will not turn in the lock
No: they are difficult to push all the way in the lock
No: they go in the lock fine, but do not turn
There is a good chance that the lock is now damaged, by inserting these new keys.
The first shim is now bend by the tip of your new key.
The tip of the new key, slides under the first shim.
Instead of sliding it in the correct position.
File the tip, like the original. More jagged.
And open the cilinder, if needed to repair the shims.
Xhorse should correct this keys cutting profile.
