What changed in v5.0.8 comparing to v5.0.4?
There is now a v5.0.9, also with no info about whats updated. I realise it must be time consuming, but come on XHorse, you should really say what has been fixed, and announce the updates. how about a mailing list for the updates ? Particularly if you want to be a quality developer of tools.
I notice that the TOY43 key clamp position has been moved, hopefully this will fix the Prius emergency key problem mentioned earlier in the thread. Had the update been announced, I'd have installed it and tested it on a vehicle today.
Yes, I updated my machine to v5.0.9 last week. It still cuts the tip of the GT15.
I have problem with XC-mini and M1 clamp try to make key for ssangyong actyon decode ok but machine cut to much
I did try universal and here problem even bigger decode ok machine cut 1 part ok but when move to the other side
it lower cutter in the middle of the key and destroy it ( will update post with pictures)
kleidaras (31st May, 2018)
Key is clamped solid cutter is ok.
Can somebody decode this two blades pls.
31344423
34331242
and your other FORT Locker Key = 3211234343
auto techniek (2nd June, 2018), M3L3R (10th June, 2018), z786 (3rd June, 2018)
Tip off second key looks fine.
Same as always
