Results 1 to 14 of 14
    tehnosoftex's Avatar
    Romania
    Default Peugeot 508 hybrid non starter
    Hi everybody, I have in my shop a peugeot 508 hybrid 2.0 diesel, which starts and stops after a second or 2. Long story short, the car has initially a problem with a ball bearing from reversible alternator. The owner has tried to change that bearing and after that has many errors and the car was in limp mode. He decide to change the reversible alternator, with a new one, the car runs , no limp but only on diesel and errors on dashboard. After he arrived in my shop I try to erase the errors, and now the car starts and stops. I have the following dtc :
    on ecm dcm3.5 I have
    U1288 invalid reversible alternator torque value sent by the hybrid management ecu 2
    P0215 main relay, poor operation of the relay, the ecu ls not being supplied as it should
    on hybrid ecu 2 I have
    p1664 engine torque information fault (security level 2)
    on hybrid ecu 1 I have
    U12c6 Length error or prohibited value of the frame from the hybrid ecu 2
    U1286 Length error or prohibited value of the frame from the hybrid ecu 2
    P1AC4 Failure of the activation of the electromotor sub assembly
    Can anyone tell me what is happening with that car?
    Thank you
    Sorin
  2. The Following User Says Thank You to tehnosoftex For This Useful Post:
    Meat-Head (16th October, 2016)
  3. #2
    chacarita's Avatar
    Argentina
    post youre vin number, did you put original part ?post number i will check in service box
  4. The Following User Says Thank You to chacarita For This Useful Post:
    tehnosoftex (31st July, 2016)
  5. #3
    Romania
    Car is gone to the dealer, will let you know what is happening with it.
  6. #4
    calin_bm's Avatar
    near civilization
    did the dealer solve it?
    Meat-Head's Avatar
    BUMP
    Main relay sounds like bsm fusebox
  8. #6
    Nov 2011
    I've got the same problem, on hybrid ecu 1 I have
    As an owner states, problem have begun after ball bearing change in alternator. I've tried to go through alternator replacement procedure but I've got
    "Initialisation of the programming the electric drive machine impossible
    programming of the electric drive machine and of the reverse alternator not carried out"
    tehnosoftex, does you client solve the problem?
  9. #7
    Dunker's Avatar
    Yorkshire
    Wink
    So an alternator bearing will make the hybrid more expensive overall to run than a 5 litre V8 with the dealer repair cost
    V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
    IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
  10. The Following User Says Thank You to Dunker For This Useful Post:
    Meat-Head (13th October, 2017)
  11. #8
    Romania
    Hi, sorry for not updating this thread, I forgot that I post it. The end of the story, the car was solve on the dealer only with online functions. The customer told me that the dealer go online with France and starts the car in about 20 minutes. It seems that for newer cars we cannot do anything without online functions.
  12. The Following User Says Thank You to tehnosoftex For This Useful Post:
  13. #9
    Meat-Head's Avatar
    Quote Originally Posted by tehnosoftex View Post
    RANT MODE:-
    DK member Drakov mentioned something couple of years ago, i tried to find out more
    from "the imi" and "smmt" and got ignored and blocked on twitter by them both.
    OFF TOPIC:-
    last week i had an argument with a peoueot car, so i rung HQ here in UK Coventry,
    "need to speak to dealer" i said they wont know the answer to my questions
    as they didnt make it! Pending calling dealers asking why such kak ideas
    not helping enviroment towing "good" cars everywhere
    OFF TOPIC:-
    read on an INFERIOR website about jcb service lights, needs to
    go to dealer for reset, great reply, i now use it explaing to customers
    "the nearest dealer is a seven hour boat ride away"
    OFF TOPIC EVEN MORE:-
    so what happens when fire deptment donate old fire engines etc to third world countrys?
    ON TOPIC:-
    what did dealer charge please?
  14. #10
    Romania
    Hi, I don't know what the dealer charge for, but the customer need to tow the car to the capital, about 250km away, because in my town the dealer wasn't able to do it, may be because in here we have only peugeot dealer and not citroen.
  15. The Following User Says Thank You to tehnosoftex For This Useful Post:
    Meat-Head (17th October, 2017)
  16. #11
    mexanico1971's Avatar
    portugal
    Hi Guys
    I have the sane situation here
    HCU2 reverse alternator P1B66 " learning not performed " , P1B6C traction battery , P1B69 electric Machine
    I read these codes width Lexia
    The car have a accident Airbags changed and no Dtc"s
    I made initialization and re-learning in several modules
    If I use diagbox to start the car , sometimes crank"s and start
    But I missing something
    Thank"s in advance
    My work is my life ART TECH GARAGE
  17. #12
    Meat-Head's Avatar
    If it is easy would change unferhood fusebox
    see millions of normal ones, no crank out put
  18. #13
    portugal
    This is main relay
    "see millions of normal ones, no crank out put" and any ideia why ?
    Enviado do meu SM-J530F através do Tapatalk
  19. #14
    Meat-Head's Avatar
    https://www.ebay.co.uk/itm/9661708080-BSM-FUSEBOX-Under-Bonnet-Citroen-C4-GRAND-PICASSO/164122241170
    the numbers must match. Not worked on hybrid with that fault so not sure
  20. The Following User Says Thank You to Meat-Head For This Useful Post:
    mexanico1971 (26th March, 2020)
