Page 22 of 171 FirstFirst ... 1217181920212223242526273272122 ... LastLast
Results 316 to 330 of 2560
  1. #316
    DashProg's Avatar
    Jan 2013
    Here
    Default >>>>>>>>SMOK SUPPORT THREAD<<<<<<<
    Quote Originally Posted by alkaskad View Post
    Anyone tried peugeot 207 bsi?
    You can do it man just plug and play
    Envoy? de mon iPad en utilisant Tapatalk
    Everything will be back in order - All my respects to DK's members.
  2. The Following User Says Thank You to DashProg For This Useful Post:
    alkaskad (21st January, 2017)
  3. #317
    Apr 2016
    Bsi by obd and dashboard manually? Any special procedure?
  4. #318
    DashProg's Avatar
    Jan 2013
    Here
    You remove dash, do the bsi by obd then you do the dash on the bench after that plug it that's all
    All my respects
  5. The Following User Says Thank You to DashProg For This Useful Post:
  6. #319
    DashProg's Avatar
    Jan 2013
    Here
    All my respects
  7. #320
    Jan 2009
    Peugeot 308 2008 yeart. Mileage can be done? What is procedure, bsi , dash....
    tnx
  8. #321
    DashProg's Avatar
    Jan 2013
    Here
    Quote Originally Posted by ziko View Post
    tnx
    you remove dash, do the bsi via obd then the dash on the bench after that plug and enjoy
    All my respects
  9. The Following User Says Thank You to DashProg For This Useful Post:
    kronk92 (27th March, 2017)
  10. #322
    Jan 2009
    Dash on eeprom or can be via dash connector?
  11. #323
    DashProg's Avatar
    Jan 2013
    Here
    You must read the eeprom then edit it
  12. #324
    Member al0503's Avatar
    Nov 2015
    hello, i have a cas 4 with 5m4e8h mask, can someone pass me pictures of the pin out, because in the smok explanation i cant see it well
  13. #325
    May 2012
    Quote Originally Posted by al0503 View Post
    Here are smok photo. Zoom to see better.
  14. The Following User Says Thank You to tziku For This Useful Post:
    al0503 (23rd January, 2017)
  15. #326
    Nov 2015
    Thanks a lot, well yesterday I found some pinout from vvdi explanation and doing some swapping information was able to unsecure, read and write.
    Enviado desde mi iPhone utilizando Tapatalk
  16. #327
    yugo45's Avatar
    All connection is in DOC folder . Find Multiprog folder in your C drive and you will see DOC folder.
  17. The Following User Says Thank You to yugo45 For This Useful Post:
  18. #328
    Nov 2015
    Thanks mate
  19. #329
    honingkoning's Avatar
    Dessert
    Today tested tv Free option (golf 7 Discovery pro) all Ok in 30 sec.
  20. The Following 3 Users Say Thank You to honingkoning For This Useful Post:
    amigokola (28th January, 2017), offsystem (24th January, 2017), ziko (24th January, 2017)
  21. #330
    Aug 2015
    Quote Originally Posted by honingkoning View Post
    Free Option ? Thought is 80?
