Drove car few meters old come back. Did dash also and all perfect. Thx to all for help
Good day, Clio 4 dashboard and Renault Trafic 4, before it worked well, today I do update and now does not function v 3.2.1.8 sample information (TTaskDialog requires Windows Vista or later), I have xp and always worked well, now with uptime does not work . Help please
trafic 4 and Clio 4 !!!!
-Fiesta 2013 airbag XC2361 clear crash ...Ok
But be noticed eeprom reraded was not read first time correctly, so better do crash clear OBD instead clear by file and write eeprom back
- mazda 6 2007year mileage read eeprom stops at 50% but change mileage is OK
rokibar (5th June, 2017)
Nissan obd had the same problem had to do it more then 6 times before it work, kept saying failed.
Anyone done a hyuandi i30 2016? mb9..... software same as some of the newer Kia's?
Thanks,
Yes I pressed CLEAR CRASH on smok
Just see what you ask, yes I did autocom to clear errors but not that as wrote on forum 10 sec On erase dtc off ... symply erase.
I also used smok read/clear error... there was airbag light later On again but they not installed pretensioners, so put resistors and airbag lamp goes OFF without erase DTC with diag tools
rokibar (30th May, 2017)
Anyone else have this problem?
Hi guys,
Anyone using smok psa for dash? Any reviews?
If it can read and write both eeprom and flash, it should be able to clone bsi right? Just a thought.
To clone the BSI it has to be in working order, otherwise can't read eeprom/flash, quite useless option? Have I missed something.
Date of publication 05.06.2017 -UHDS ALLInOne 3.2.2.2
Fixed option Opel DashBoardKline (Corsa,meriva ,Agila, astra...) -Added Read Pin Dashboard Corsa C,Meriva, Combo
Date of publication 05.06.2017 -UHDS ALLInOne 3.2.2.1
Added new option Body Fiat Delphi - Decode EEprom data, now we get all information required for make transponders
having an issue after PCR2.1 swap, anyone done 1 of these on a passat
i have dumped the comfort module to get pin cs etc as you cant get it from dash, and followed the instruction in the guide but always 'start blocked by immo' fault after i adapt the doner ecu.
can anyone confirm the correct procedure?
the doner ecu is from a seat
i have checked the smok videos -they adapt a audi a1 ecu into a golf 6
https://www.youtube.com/watch?v=nUZnpD78r4Y&t=2s
https://www.youtube.com/watch?v=RDU8WmNDYuk
