megane III vdo, kill dash when flashing ABS
The meter does not switch on
replacement of the meter and all OK
bcm2 elv adapt online offline -echange immodata -clone immodata sinchro bcm elv medc17 edc17 Crafter EZS e EDC17 sinchro -DPF/ EGR/ DTC/ removal/: IMMO ADAPT edc16 EDC17 edc17c64 C74 NOW WORKING MED17/MEV17/ VAG ecu clone full working all
PCR2.1 FULL CLONE ou adapt, clone all edc17 me17 , etc / dash echange immodata repair immodata add key etc etc
eventually got this - guess i was using wrong flash file...but another strange problem with comfort module...if battery is disconnected the module loses vin etc, i then need to write the original dump back to it so that it works again????????
surely this is not normal, i tried with another module, same issue?????????
rokibar (30th June, 2017)
By obd no
Now no com with Dashboard
Or can you explain me how do
Ok i ll try and report
Thank you
Today i tried peugeot 308 from 2014, but smok cant do it, said bsi prog error.
Anyone tried that option?
Since the last update the bsi Valeo don't work in 2014 cars , it work before
