kronk92 (21st July, 2017)
i already tried all options and nothing, on website they said :
- Valeo Old (all version) Read Pin
- Valeo New (all version) Read Pin
Change mileage on jc bsi Peugeot 308 2009.
I have test fast write with lock dash-bsi mileage ---> result is no mileage on dashboard... Just "-------"
After that I have write back original all work great.
I have tested with normal change mileage with lock dash-bsi and same restult.
Problem solved by maki hello bsi by obd and dash by eeprom. Problem is from lock dash-bsi mileage.
With Tapatalk
Question about DENSO tool - does it make Opel VIRGIN as I/O TERMINAL? or only read/write flash?
on the k line stuff are you updated v3 multiplextor board ??
or have you done the wire mod on your lead ?
if neither then you will have problems
dave
Tools owned.
AVDI commander.
Dashfixer orig.
Dashfixer clone.
Fiat km tool.
Opel km tool.
Ford KM tool.
Op--com colne.
Lexia & PP clone.
Smok PSA, volvo & ford
If someone helps you DONT FORGET TO SAY THANKS its only polite....
kronk92 (1st August, 2017)
I don't have the new multiplexer board, juste done the modification with an adaptor.
i did a 307 other week and dash went to - - - - -
tried all sorts
in the end with the bsi and dash having my desired km programmed back into it
it was still on - - - - -
i wrote the original flash back to the bsi
this removed any synchro blockage in the bsi and showed my km back up
6 months later i did the vehicle again
and for the life of me i could not get the - - - - - - away from the speedo
so i said
drive it for 50 miles it will pop the km back up
and ya know what..... it did
dave
Tools owned.
AVDI commander.
Dashfixer orig.
Dashfixer clone.
Fiat km tool.
Opel km tool.
Ford KM tool.
Op--com colne.
Lexia & PP clone.
violator11 (19th August, 2017), yugo45 (5th August, 2017)
Can smok clone a dash via obd if I read the original eeprom and write it into a donor unit?
If the read and write eeprom is highlighted on the dash menu i would say yes but sometimes it is only write km that is highlighted
sjc1 (11th August, 2017)
Someone tried vivaro trafic year 2016 2017, dash and abs synchro block by diag ? Does it work ?
Envoyé de mon iPhone en utilisant Tapatalk
Ayone have any experience with the 2016- transit does it work or does it jump back like elprosys
All about the Bass
Ocin (17th August, 2017)
Did someone had any succes on a med9.5.10 in a vag car with smok.
I tested now on 3 cars but always error.
I work like described in pdf but for me it did not worked, so end up in immo off solution.
Edc/med17 worked good also adapting used dashboard in several vag cars worked great for me.
Wbr Adam.
Does Smok support mileage correction on golf 7 early models(2013)?
