Page 53 of 171 FirstFirst ... 343484950515253545556575863103153 ... LastLast
Results 781 to 795 of 2560
  1. #781
    is this cluster supported by the new VDO function
  2. #782
    double post my bad
  3. #783
    Jan 2009
    Not same ecu number, and I not wanna open donor in case we need to get back , but now I think, normally cant write mac1 when I do on bench, must try WRITE on CAR, will try tommorow
  4. #784
    Nov 2012
    Then full bdm is the perfect solution.
    But yes You have to open-it.
  5. #785
    honingkoning's Avatar
    Dessert
    Quote Originally Posted by ziko View Post
    Did one last week, same ecu smok was not able to do it.
    Finally finished job with good old VDC (vag dash can).
    Just copied eep, flash you cant write on desk, due to immo active.
    You can make immo off in eep, write flash and after that make immo on again.
    Wbr Adam.
  6. #786
    yugo45's Avatar
    Quote Originally Posted by djollie View Post
    That is Golf7 , SMOK do not support it at all.
  7. The Following User Says Thank You to yugo45 For This Useful Post:
    djollie (19th September, 2017)
  8. #787
    Oct 2010
    Every-tool now has this software, DP4, Engima, Smok, hmmm where to buy it from
  9. #788
    Dessert
    Quote Originally Posted by sparkz02 View Post
    Lets see How long it Will take for x100 pro to get this update .
    Might be Free
  10. #789
    Aug 2015
    Buy it from the developer smok not from the cloners.
  11. The Following 2 Users Say Thank You to offsystem For This Useful Post:
    cokolo (20th September, 2017), yugo45 (20th September, 2017)
  12. #790
    Quote Originally Posted by offsystem View Post
    i dont think anyone have clone this update.
    think the one that had cracked it just sold it to the others or it was a join venture.
    because the companys coming out with the update every day after each others.
    smok, 1 day later a other, 1 day later a other, ect, ect.
  13. The Following 3 Users Say Thank You to vageric For This Useful Post:
    electromech (20th September, 2017), xm3n (20th September, 2017), yugo45 (21st September, 2017)
  14. #791
    electromech's Avatar
    Behind a large rock
    Quote Originally Posted by vageric View Post
    I agree I would like to know who the actual developer is as it seems everyone is just buying new functions without the R&D
  15. #792
    Jul 2016
    We have one forummember who could put some light on this, but it is his decision to stay in the dark. Lets just say that maybe one initially cloned/bought it and put it public (guess who). From that point all other companies had a hint where to look for a solution. If you know the process of programming these dashboards in detail (not just "a bootloader is used") then this hint that smok put public was sufficient.
  16. #793
    Faraday's Avatar
    May 2012
    The dark side of the moon
    New update:
    Date of publication 20.09.2017 -UHDS ALLInOne 3.2.4.5
    Read EEprom,Write EEprom, Read Km,Write Km, Read Security Block, Write Security Block , Learn Key (only for user with active license Immo Tool):
    Audi Q3 TFT 06/2014...
  17. The Following 2 Users Say Thank You to Faraday For This Useful Post:
    amigokola (24th September, 2017), yugo45 (21st September, 2017)
  18. #794
    Jan 2009
    Something not clear to me when need to replace edc16 ecu
    1. Present Component Security (6 bytes) of ECU
    2. Present PIN code (always must be write in format 5 digits) of ECU
    3. Power class of ECU. If we don't know power class of ECU program automatically find it and inform us what is this value.
    4. New (target) Component Security 6 bytes (same as in Immo System in car)
    5. New (target) PIN Code (same as in Immo System in car)
    6. New (target) VIN Number (same as in Immo System in car or can be another)
    7. NEW Immo ID ( target). (same as in Immo System in car or can be another)
    After preform operation ECU store new Immo data and automatically learn MAC1.
    Next step is go into Immo3 ( or Immo4 depend car system) and change Immo data in Immo module. This operation is necessary for learn MAC2.
    After this step ECU is learned to car and ready to use.
    After change immo data we must learn MAC . Go into Immo3 option (or Immo4) and with PIN Login to immo system.
    It write need to go immo3 or 4 and CHANGE immo data in immo module (is this mean I will change ori immo data in immo module) ????
  19. #795
    no
    only adapt mac 2
    bcm2 elv adapt online offline -echange immodata -clone immodata sinchro bcm elv medc17 edc17 Crafter EZS e EDC17 sinchro -DPF/ EGR/ DTC/ removal/: IMMO ADAPT edc16 EDC17 edc17c64 C74 NOW WORKING MED17/MEV17/ VAG ecu clone full working all
    PCR2.1 FULL CLONE ou adapt, clone all edc17 me17 , etc / dash echange immodata repair immodata add key etc etc
  20. The Following User Says Thank You to koyot For This Useful Post:
    ziko (22nd September, 2017)
