Page 59 of 171 FirstFirst ... 949545556575859606162636469109159 ... LastLast
Results 871 to 885 of 2560
  1. #871
    Aug 2011
    km audi a6 a8 tuareg .....2011--2015 tested ok by eeprom prepare
    dacia dash/ abs ok by OBD
    dacia duster ecu SID 306 read km but NO write.......done by CLIP reprog
    dacia airbag spc ....done by OBD
    iveco bcm km by dump ...ok
  2. The Following User Says Thank You to ciptel07 For This Useful Post:
    teerak2uk (15th October, 2017)
  3. #872
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by ciptel07 View Post
    What year/model dacia?
    What version clip/reprog?
  4. #873
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    Hi experience with this vehicle, protocol MS0005 work?
    W117
    Mercedes CLA
    W176 Class A
    W246 Class B
    W166 Class M
    W463 Class G
    test solution? work??
    ThK
    ..Ecu Repair ... Steering Wheel Repair ... Dash Repair ... AirBag Repair .... that Bad LiFe ...
  5. #874
    W117 Mercedes CLA : tested and works
    tested and workstested and workstested and works
  6. #875
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    Quote Originally Posted by gogo660tc View Post
    Work ?!
    I installed filter emulators, as instructed, in dashboards and EZS, car star, all ok.
    Start work on OBD to vary values, read data km , but do not modify
    " Unlocked memory error !! "
    what is the problem ??
  7. #876
    honingkoning's Avatar
    Dessert
    Quote Originally Posted by centrohifi View Post
    Work ?!
    Not supported dash, open dash and do it by eep.
    Wbr Adam.
  8. The Following User Says Thank You to honingkoning For This Useful Post:
    yugo45 (20th October, 2017)
  9. #877
    Aug 2011
    dacia ph2 after 2013 and CLIP V156 and reprog ......and after reprog in engine ecu will be 0 km
  10. #878
    Work ?!
    first, try programed by obd,
    3 of 4 cars , it works
    my experience
    first try to change the value for a moment, then install can filter. and reprogram the value
    works on 3 out of 4 cars
    my experience
    .first try to change the value for a moment, then install can filter. and reprogram the value
  11. #879
    Aug 2015
    Opel Corsa C with DELCO 1,7 D ecu, i read eeprom and copy to donor ecu but IMMO is ON.
    there are differences in the EE
    Is cloning not possible ?
  12. #880
    Jan 2009
    Quote Originally Posted by offsystem View Post
    Try to reset cluster and body
  13. The Following 2 Users Say Thank You to ziko For This Useful Post:
    offsystem (22nd October, 2017), rokibar (21st October, 2017)
  14. #881
    Dessert
    Quote Originally Posted by ziko View Post
    Reset cluster,reset body, erase keys.
    Adapt all again and it should be good,
    Wbr Adam.
  15. The Following User Says Thank You to honingkoning For This Useful Post:
  16. #882
    Oct 2017
    New Zealand
    Hi, Apologies if this is not right place to post.
    New UHDS user. I have Peugeot 307 2006 with Johnson Controls no crypto. Plug in UHDS, told to program BSI only (no dash) by sales, new mileage appears on display, but after 10 mins old mileage reappears.
    Sales say my BSI has been tampered with, but very unlikely. Say I must use eeprom tools to modify dash and UHDS for BSI, but if my car has NEC processor forget it...
    Could someone please advise the correct procedure for P307 2005->?
    Should I use the C4 Dash tool in UHDS?
    I have dumps of the EE and Flash if useful prior to being modified if anyone is able to assist as to why UHDS doesnt work?
    I did try Set block synchro as well but also did not work...
    Zedd
    (ps - ignore communication error in the log file - i forgot to turn on ignition once )
  17. #883
    Serbia
    Quote Originally Posted by ZeddNZ View Post
    Zedd
    if you have JC bsi then in cluster have eeprom 25020 or 25040
    make picture of cluster
  18. #884
    Oct 2017
    Normally bsi obd cluster manually
  19. #885
    Oct 2017
    New Zealand
    Quote Originally Posted by Iffy2008 View Post
    Thanks Iffy2008, but I bought SMOK UHDS for P307 205- because it was supposedly able to change dash and BSI all from OBD. I try to understand why it does not work. Developer says problem with BSI?
    ZeddNZ
