Page 60 of 171 FirstFirst ... 1050555657585960616263646570110160 ... LastLast
Results 886 to 900 of 2560
  1. #886
    Oct 2017
    New Zealand
    Quote Originally Posted by kizagt View Post
    if you have JC bsi then in cluster have eeprom 25020 or 25040
    make picture of cluster
    Thanks Kizagt - i attach photos of cluster. I am unsure how to pull apart further without damage to gauges, can you explain please?
    Hopefully the part numbers may help to identify eeprom inside?
    ZeddNZ
  2. #887
    Oct 2017
    New Zealand
    Hi Looks like ST95020...
    Can this eeprom be programmed in place (in dash), or must be de-soldered? Can I program through cluster plug? or clamp onto chip?
    What is best tool for this? I will only be doing this car no others, so prefer something cheap! Already spent much money on SMOK tool and it does not work for this car...
    I also need to do this car many times, so something easy to use would be preferable!
  3. #888
    Serbia
    Quote Originally Posted by ZeddNZ View Post
    You need eeprom programer to do this cluster
    Best way is take out eeprom and read
  4. #889
    Thanks Iffy2008, but I bought SMOK UHDS for P307 205- because it was supposedly able to change dash and BSI all from OBD. I try to understand why it does not work. Developer says problem with BSI?
    ZeddNZ
    It not change km dash, it only change km BSI. and what is vissible on display dashboard comes from bsi and not from mileage in memory dashboard. If there is a problem with bsi the block function not work. So mileage from dash go to bsi and display dashboard show old km...
  5. The Following 2 Users Say Thank You to gijsvm For This Useful Post:
    teerak2uk (24th October, 2017), ZeddNZ (24th October, 2017)
  6. #890
    Oct 2017
    New Zealand
    Quote Originally Posted by gijsvm View Post
    Thanks - is there a way to fix BSI so can program via OBD? Should I try write original download back to flash and ee?
  7. The Following User Says Thank You to ZeddNZ For This Useful Post:
    Iffy2008 (25th October, 2017)
  8. #891
    Oct 2017
    New Zealand
    Yes thanks - I mean what is a good programmer? UPA-USB copy from eBay? What do people recommend?
  9. #892
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Yes but not suitable for in circuit programming so remove eeprom for read/write
  10. The Following User Says Thank You to teerak2uk For This Useful Post:
  11. #893
    ghostrider72's Avatar
    Jul 2012
    UK
    Is it possible to adapt used ECU MED9.1 to golf mk5 with Smok? Never did that one, only EDC16’s so im not sure.
    Old ecu has been flooded but i can still pull the data out of the clocks.
  12. #894
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    In my immobox...
    @ghostrider72: Yes, i made one on Q7, no problems at all.
  13. The Following User Says Thank You to lupu_sandu For This Useful Post:
    ghostrider72 (25th October, 2017)
  14. #895
    Oct 2017
    The best tool is Abrites for all psa Peugeot & Citroen. Well I use a few tools
  15. #896
    didi_du_93000's Avatar
    France Paris
    Quote Originally Posted by Iffy2008 View Post
    Abrites is:
    888 + 1400 + 1400
    Abrites make BSI partner 2015+ (with SPC560) only since 1 year when SMOK make it since 09/2015
    Abrites make cactus since 09/2016 and SMOK 07/2016
    But YES Abrites make some work than SMOK can't do it (like Continental after 2015, some bsi crypto don't work with smok....)
  16. The Following User Says Thank You to didi_du_93000 For This Useful Post:
    yugo45 (28th October, 2017)
  17. #897
    honingkoning's Avatar
    Dessert
    Quote Originally Posted by ghostrider72 View Post
    Tested on 2 cars But never worked for me, But you can open and swap eep.
    Just look for the same ref.
    I followed procedure like ik manual But No succes.
    Wbr Adam.
  18. #898
    Jul 2012
    UK
    Thanks. Ill try adapt it first. Easier way i think
  19. #899
    Oct 2016
    Hallo guys.. I have lic. for smok Ford cars. And i have question. Some cars have in ECU written totdis and u can read original km. Is any solution to write in ecu too? Some focuses smaxes mondeos after year 2011 have it. Have you ever seen it? Can I change it too? and what tool I need. Thank you Orynx
  20. #900
    Oct 2015
    How do you guys like SMOK UHDS for VAG and Mercedes?
    I am looking at tools for cloning DASHBOARD primarily and some ECU but reading mixed reviews on this tool for that, and also slowing of updates and innovation for future.
