Page 67 of 171 FirstFirst ... 1757626364656667686970717277117167 ... LastLast
Results 991 to 1,005 of 2560
  1. #991
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by Faraday View Post
    I don't know about punto but alfa 147 all key lost read eep(dgxxx) no problem. No limitation on saved dumps. I have UHDS few years now and never had problem with hardware. I have never heard about faulty usb socket but I know it requaire good quality USB cable.
    so don't need the pin code before the operation? Sounds good
    thanks!
  2. #992
    Faraday's Avatar
    May 2012
    The dark side of the moon
    Quote Originally Posted by jodge View Post
    thanks!
    You can add key to dump but you need other tool that work on dump like EFFI.
    Smok body can only read/write dump and calculate pin code ( in some case calculate wrong).
  3. The Following User Says Thank You to Faraday For This Useful Post:
    yugo45 (10th December, 2017)
  4. #993
    jodge's Avatar
    Mar 2017
    Maybe you misunderstand I know the TP part it's not a big deal. But the trucode must need the pin -=before=- read the eeprom (maybe to entering the service mode..or something similar) only with the marelli type 1 BSI(punto mark II..etc) thats why i'm curious.
  5. #994
    dave11674's Avatar
    Florida, UK
    has anyone used smok for denso ecu ?
    2.5 / 3.2 ?
    if so how did you do it and what was procedure ?
    what about hours too ?
    dave
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
    Smok PSA, volvo & ford
    If someone helps you DONT FORGET TO SAY THANKS its only polite....
  6. #995
    Feb 2011
    Newest software download is corrupt for the UHDS and will not update. Anyone run into this??
  7. #996
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Had it sometimes not update with bad usb cable
  8. #997
    Jan 2016
    I have the same message.
    Quote Originally Posted by JandJSpeedShop View Post
  9. #998
    rob h's Avatar
    May 2011
    I just did, all went fine.
    Bosch NEC 70F3558+24C32 OBD new added
  10. #999
    Feb 2011
    Quote Originally Posted by amigokola View Post
    Same here unless there is a better place to download the software???
  11. #1000
    dave11674's Avatar
    Florida, UK
    Goto website
    click downloads on x bar
    then goto
    ALLINONE> update
    and grab exe from there
    WARNING
    always use a high quality usb cable when using uhds
    also when flashing it
    remember just cos you bought a cable from maplis @ £29.99
    does not mean its a high quality one
    they buy cheap crap and repackage it
    best ive found are the china blue see thru cables
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
  12. #1001
    dave11674's Avatar
    Florida, UK
    On a side not
    the new body software will be relabeled too as it does not say which vehicles its for
    new astra/insignia
    dave
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
  13. #1002
    Jan 2009
    I get last year full smok, now every update must pay like someone get that module only, for example fiat marelly ecu, I need 2 module from smok
    EU0022 (IAW 59F,IAW5AF,IAW4AF) = 320 eur
    EU0025 (Magneti 8GSF ,Magneti 8GSW ,Magneti 8GMW) = 320 eur
    Total for those 640 eur, io terminal those plus other ecus I already paid in full uhds (iaf 6f3,iaF 8F3) COST cheaper then update for smok full user.
    Also today I needed ducato bsi with 93c86, smok update for this 440eur (((
    Full fiat bsi ioterminal cheaper themn only this update for ducato
    I cant understand smok seller, beter for me to have one in all tool but because of price will have to get ioterminal too
    regards
  14. #1003
    Quote Originally Posted by ziko View Post
    regards
    U can buy yearly subscription for 1500 euros
    Sent from my SM-G950F using Tapatalk
  15. #1004
    Jan 2009
    I know, but generally prices are too high
  16. #1005
    mikhailzgv's Avatar
    Aug 2012
    Furstenberg/Havel
    Default VW B8
    I bought the license. It is stated what does Passat B8. Really doesn't do. It that deception?
