W204 2011 facelift color dash.
Obd ok (without filter)
norman1967 (19th January, 2018)
hello
have some one tried vw polo 8 sw0290 sw 0260 2015 years with smok license vw p3 cost 1200 euro
Readed pin from astra g 1.4 1999year and after that engine light on,dtc P0602 - Control Module Programming Error . Removed car accu, reseted ecu and readapt,but still dtc p0602
Was on car
Carprog also have pinout on table but read in car too. I think pinout on table is if ecu already removed from car
Just came astra G z16XE for ecu swup, used ecu I readed pin on table (and again p0602), ori on car and both have p0602.
In car ecu I connected carprog and READ ALL, reset ecu, and after that no more p0602
VW - PQB Cluster
Part No: 5N0920883G
SW :1008
HW :04
Not work
Did anyone unlock?
Part No: 5N0920883G
SW: 1007
HW: 04
Work
A3 after 2007... same dashes one can't read pin or adapt key or read eeprom,sec byte....
ID: 8P0920900S 0560yq8KOM
_________________________________
Dash Type: A3,TT,R8 2007...
ID2:
HW: H18
SW: 0560
Init Ok
Disconect Accu for 30 secunds
Read Sec Block Error
This one is OK:
ID2:
HW: H18
SW: 0560
Init Ok
Security Access Ok
Security Access Ok
Read SecB Block Ok
PIN=xxxxx
hello
can some try adjust km for polo sedan 2015 sw0214
If there are any problems with functioning Interface UHDS it is important to update the software into v 3.2.9.4 and then flash the Interface (Tools –>Flash from soft).
Best Regards/Pozdrawiam
SMOK TEAM
dave11674 (1st February, 2018)
