Page 81 of 171 FirstFirst ... 3171767778798081828384858691131 ... LastLast
Results 1,201 to 1,215 of 2560
  1. #1201
    pierre renault's Avatar
    Jan 2013
    For me XC60 does not work, the old value comes back
  2. The Following User Says Thank You to pierre renault For This Useful Post:
    Mak88 (24th April, 2018)
  3. #1202
    cokolo's Avatar
    Oct 2010
    Springfield :-)
    Quote Originally Posted by Mak88 View Post
    Hello how are you tomorow will came Volvo Xc60 2012 for mileage calibration how i need to do for good job can you little help me becousei.m new with smog thanks alot
    Sent from my Lenovo K53a48 using Tapatalk
    For XC 60 2010+ you have few version where is the location of mileage . You have two version which you can change km 1. Reprogram CEM+ dash 2.Disable sinchro CEM-dash when you make new km on dashboard don't forget to check DDM/PDM if these module have stored old km you must do manually (on OBD read fleash+eeprom than with Jtag BDM erase full NEC in DDM/PDM and write flash which you prevous reading on OBD with UHDS) if you dont want to old km jump back :-) and at the and check ECU if you vant to make clear job .
  4. The Following User Says Thank You to cokolo For This Useful Post:
    Mak88 (22nd April, 2018)
  5. #1203
    May 2017
    Hello can you help me how to make volvo disley language change volvo V50 there is read flash i read the flash and now how to make it thanks alot
  6. #1204
    Oct 2015
    now write file with other language, or change it manually in file
  7. The Following User Says Thank You to andro822 For This Useful Post:
    Mak88 (27th April, 2018)
  8. #1205
    May 2017
    U dont know how to change file my friend
  9. #1206
    hi
    i've got a 2016 vw scirocco to do with dsg, is this safe to do with smok.
    dj
  10. #1207
    Oct 2015
    shure i know how to edit volvo language. open file im hrx editor and have fun. is not easy but can be done
    cannot make 2016 dsg
  11. The Following 2 Users Say Thank You to andro822 For This Useful Post:
    djollie (6th May, 2018), Mak88 (2nd May, 2018)
  12. #1208
    ghostrider72's Avatar
    Jul 2012
    UK
    Quote Originally Posted by djollie View Post
    hi
    dj
    Yes. All will be fine
  13. The Following User Says Thank You to ghostrider72 For This Useful Post:
  14. #1209
    May 2017
    Do you know qhat is the wey for Citroen jumpy 2007-2012 how to make it and how to clear this history and edc16 how to make it good job with smok thanks advance
  15. #1210
    Quote Originally Posted by andro822 View Post
    Quote Originally Posted by ghostrider72 View Post
    dsg can be done or not????
  16. #1211
    Nov 2010
    of my experience does not work
  17. The Following User Says Thank You to Repinator For This Useful Post:
  18. #1212
    cokolo's Avatar
    Oct 2010
    Springfield :-)
    On OBD NO, but you can use Smok DSG filter and everything is been OK
  19. The Following 3 Users Say Thank You to cokolo For This Useful Post:
    djollie (6th May, 2018), rokibar (3rd May, 2018), SKYTON (6th May, 2018)
  20. #1213
    Member al0503's Avatar
    Nov 2015
    For this car, no problem just block the kms and do the quick writing
    Enviado desde mi iPhone utilizando Tapatalk
  21. #1214
    Jan 2009
    Lancia Delta dash 2009 = ok in 5 seconds
  22. #1215
    drpeter's Avatar
    The Netherlands
    Quote Originally Posted by ziko View Post
    Aynone have problems with the interface last months? I have a old version interface i have many read flash errors while reading a dash. also flashing the update sometimes goes wrong. I changed the multiplexer inside for a new type, same problem. I have one of the first designs so i wonder if someone have the same problems. I bought already a new laptop also. Smok thought it was my laptop. thanks.
