teerak2uk (20th June, 2018)
shotaaa (21st June, 2018)
pierre renault (24th June, 2018)
http://www.digital-kaos.co.uk/forums...=1#post3309482
what wold be the next step to recovery
thank you
Watch this 2 videos from SMOK.
https://www.youtube.com/watch?v=nUZnpD78r4Y
i did it in the same way jut was unlock with galletto ori , after i go to write mod file and error feedback from galleto was ecu rejected programming, all this was done on table.
after this galletto do not communicate anymore with ecu, boot mode or no boot mode.
after take smok and try to Write org.Flash -> got CHK error
i try to unlock one more time and try flashing same result
Tray to unlock with PCR2.1-.exe same result
Check unlock/lock status (you cant do it with SMOK unfortunetly) and flash with orig file.
clauberty (3rd July, 2018)
You can only try once with galletto to unlock
Once it’s done blocked it tells you
And if you try more than once with Galletto to unlock
You will damage the Ecu
Hi, ABS ESP CLIO 4 anyone knows if it works?
renault and dacia after impact clear fault in motor ecu and car start
pierre renault (27th June, 2018)
Hello all, I have a question regarding Smok Volvo language pack. I would like to know how to change the radio frequency reception of a japanese imported v50 or s40 into europe, so it receives local radio stations. I believe SMOK can do the language, but also need radio?
Can anyone help?
Anyone done a 2010 Peugeot 308? It reads successfully then says it writes the km successfully but shows ------ on the odometer and reverts to original mileage after a few minutes?
