Citroen Berlingo 2007. SMOK read PIN ok. Eeprom saved. But it wont code keys. Says ignition is off, but its on
Does any one have that problem?
Simens BCI on Kline
Unfortunately nope.
Can faulty ignition lock cause that?
Yes it does turn, lights are ON
Check back of ignition for supplies
Will do Monday mate. Waiting for parts atm. Thanks
P.S.
check your inbox plz
i have a hco5 adapter all the pins were soldered on board joinded i contact smok says it okay but when i put on chip on hco5 doard saying cant read mcu if nay one has a picture of there hco5 i can then check its like mine as im sure its not right
HELLO I make renault Master 2012 the dash is ole but in yhe ecu there is have km still do you know how to make it there also
RENAULT MASTER 2.3DIESEL
Sent from my SM-J530F using Tapatalk
Hello i tried today w204 2012 first synch. ZGW and after tried to change dash. It says write compleet but the dash km dont change. I tried with function "without can filter"
Somebody know how to solve it ?
Regards.
I added a key to a 2012 caddy today with VDO nec+24c64 dash, key coded succesfully ,although i did repeat the process due to not being familiar with the job.
Afterwards i noticed there is 3-7 displayed in dash,on normal mileage line. So I have done something wrong.
Smok will not allow me back into dash, I have "Security Access Error 1F"
Any ideas on resolving this ?
Regards Eck
r6eck (13th July, 2018)
