Page 87 of 171 FirstFirst ... 3777828384858687888990919297137 ... LastLast
Results 1,291 to 1,305 of 2560
  1. #1291
    Jan 2016
    Someone here swapped MM cluster (Mii,Up,Citigo) with success ??
    I read ori and new (used) and got all data.
    Prepared new eeprom and wrote it with programmer to new dash (SAFE on LCD).
    I did Immo4 UDS option in SMOK and all went smooth. Learned key (key accepted so CS,PIN has to be right) but still SAFE on dash.
    I think MAC is the problem. Dont know if SMOK works with this MM dash as IMMO4UDS option (it is not listed in manual) ??
    Any ideas are welcome...
  2. #1292
    ghostrider72's Avatar
    Jul 2012
    UK
    Try VVDI2 mate.
    I didn’t replace dash just coded mechanical key with and worked fine.
  3. #1293
    Jan 2016
    Yes adding key works with VVDI2 and SMOK but when I write data by OBD2 with VVDI2 SAFE on LCD.
    Quote Originally Posted by ghostrider72 View Post
    Try VVDI2 mate.
  4. #1294
    Jul 2012
    UK
    Type down all data manually instead of copy it. Than make new transponders
  5. #1295
    Jan 2016
    I've already did it and immo see keys as dealer key. I wrote all data by hand and still SAFE on dash. This car is killing me...
  6. #1296
    Jul 2012
    UK
    Pretty sure there is option in SMOK to pair clocks with ecu. I’ve used it only once or twice in the past. Worth to try that as well
  7. #1297
    Sep 2016
    Power class match? Did you perform ecu learning to dash?
  8. #1298
    Jan 2016
    I did Immo4 UDS and all went smooth. Disconnected battery for 15min but still SAFE on dash. Problem is in ecu-immo line. I think MAC but even when I login it doesnt help. It is ME17.5 so I dont know if Smok works good with this ecu combined with MM dash... What tool decode data feom this ecu ??
    Wysłane z mojego SM-G950F przy użyciu Tapatalka
  9. #1299
    yugo45's Avatar
    Quote Originally Posted by amigokola View Post
    Try direct read at ECU with SMOK , it should decode data.
  10. The Following User Says Thank You to yugo45 For This Useful Post:
    amigokola (19th July, 2018)
  11. #1300
    Default CITROEN C1 2017 MILEAGE ?
    can smok do CITROEN C1 2017 MILEAGE ?
    i haven't got to the car yet so no idea what bsi or cluster is in it???
  12. #1301
    Aug 2015
    Can smok uhds do peuguet 3008 2017 odometer
  13. #1302
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by djollie View Post
    Is c1 not a toyota underneath and dash/eeprom only???
  14. #1303
    Maartinj's Avatar
    Nov 2010
    simple disconnect ECU to see if cluster see KEY and message gone
  15. The Following 2 Users Say Thank You to Maartinj For This Useful Post:
    amigokola (20th July, 2018), yugo45 (20th July, 2018)
  16. #1304
    Quote Originally Posted by teerak2uk View Post
    Is c1 not a toyota underneath abd dash/eeprom only???
    I THINK YOUR RIGHT??
  17. #1305
    esse's Avatar
    france
    Today try scenic IV and megane IV dash continental and perfect
