Hello
other day i had to do milage on master 2018
did cluster vith smok ok but engine ecu sid310
it didnt do it reseted some lines but total milage
in engine ecu it didnt cange. Is there any trick or
just read write process?
Hello
Audi A4 2014
Ive had two A4 Audi,s that have failed to find login code, They have went all the way to the end of the search.
Is there a solution for this ?
Will going to eeprom work?
Thanks Eck
teerak2uk (3rd August, 2018)
Dear Friends,
I think smok is not good for mercedes i have a problem with milleage correction W212 2013 (facelift with color display) by Smok
Orginal km 348xxx i wanna change on 138xxx but now show dash that its 1.6 million km
i had block synchro succesfull afther that i changed km and it wasnt working it was directli 1.6 million km
i tried 4 times and 4th time it was succesfull client goes home and day afther it was again turning back on 1.6 million
and when i read now EZS it shows 500 xxx km .So what can i do?
do i need a can filteR?
Nothing wrong with Smok either try with different tool or put can blocker
i am trying to read micronas with smokjtag from golf V dash and cant bypass security. i checked all cables and all is ok.
anyone have problem with this?
delete this
good day friends I have smok my question is if in the license of fujitsu is only to read them or when reading gives you the mileage of the board to modify someone has the license for fujitsu thanks in advance
what pack used for the cluster audi a4 2017 cluster is on the pictures .
Attachment 548401
Someone had a problem with edc17c46 Skoda Super B .......?Smok cant transfer Immo data property......car starts one time....after second tray car wont start and have DTC
-P0610 - engine control unit incorrectly coded
-P160A - check sum error
-P1570 - engine start blocked by immobilizer
-U140A - Terminal 30 - open circuit
Baze007
