Page 91 of 172 FirstFirst ... 41818687888990919293949596101141 ... LastLast
Results 1,351 to 1,365 of 2569
  1. #1351
    Mar 2011
    EU
    Tried today kangoo 2017, doesn't work, Said unknow version
  2. The Following User Says Thank You to Ocin For This Useful Post:
    Nicolas9 (7th September, 2018)
  3. #1352
    Nicolas9's Avatar
    Feb 2017
    Aruba
    Quote Originally Posted by Ocin View Post
    Thnx. Do you which month?
    By the way, you could just read eeprom.
  4. The Following User Says Thank You to Nicolas9 For This Useful Post:
    Ocin (7th September, 2018)
  5. #1353
    Nicolas9's Avatar
    Feb 2017
    Aruba
    i dont see option for W447 by obd.
    does it work using the w205 option? (luxury dash of w447)
  6. #1354
    Mar 2011
    EU
    Quote Originally Posted by Nicolas9 View Post
    02/2017, done with avdi original, work fine !
  7. The Following User Says Thank You to Ocin For This Useful Post:
  8. #1355
    honingkoning's Avatar
    Dessert
    Quote Originally Posted by shotaaa View Post
    And how about year 2012 or older models did you tried with smok ?
    I Did a lot JC dashes with smok all ok.
  9. #1356
    Dec 2017
    W176 2013 must put can filter and after change km thru obd ? or change km manuel after put can filter and put cluster back in to the car ?
  10. #1357
    Nicolas9's Avatar
    Feb 2017
    Aruba
    first check if works by obd. then remove cluster and put filter (if not work obd. then open cluster first and program eeprom).
    if you put only one filter dealer can find mileage easy in ezs.
    there are also mileage stored in many more other locations.
    probably car will give DPF error if its diesel, then reset dpf with star diagnosis
  11. The Following User Says Thank You to Nicolas9 For This Useful Post:
    shotaaa (28th September, 2018)
  12. #1358
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    I activated RT009, for Renault Captur, identifies but does not modify!
    They tell me to buy RT018 .... paid another 140Euro, identify ok reading eep OK, but do not change value !!! a disaster ....
    ..Ecu Repair ... Steering Wheel Repair ... Dash Repair ... AirBag Repair .... that Bad LiFe ...
  13. The Following User Says Thank You to centrohifi For This Useful Post:
    didi_du_93000 (25th September, 2018)
  14. #1359
    Apr 2014
    does smok correct ckecksums when flashing ecus flash memory?
  15. #1360
    Quote Originally Posted by centrohifi View Post
    RT0018 works, tested on 2018 car,
    you must make abs before or reflash dash
  16. #1361
    Dec 2017
    Thanx for informatioen mate.
    It worked thru obd, it was a diesel but no DPF error.
  17. #1362
    May 2017
    Espaņa
    Hi all, i have a Radio RCD310 with Nec 70F3353 and i cant read it. anyone know how i can do?
    i have pinout for orange5 but i have original orange5 and dont have this activation.
  18. #1363
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    Quote Originally Posted by goran81 View Post
    my car 2016 !
  19. #1364
    Sep 2016
    Then you get wrong license. RT0018 is for 2018. Distributor or your error not device.
  20. #1365
    Jun 2016
    what pack used for the cluster audi a4 2017 cluster is on the pictures .
    Attachment 548401[/QUOTE]
