Page 102 of 171 FirstFirst ... 25292979899100101102103104105106107112152 ... LastLast
Results 1,516 to 1,530 of 2560
  1. #1516
    Jan 2009
    Dash dead,if was ok was easy,just read and write sec data and job done
  2. #1517
    Sep 2015
    Quote Originally Posted by ziko View Post
    But I changed instrument cluster not ecu,if I change immodata in edc16 then keys will not be able to relearn
    Edit: I just saw in help that you are right,in edc16 I write ori car data just to learn mac1,will try next car
    Edit: maybe must use new megamos
    But lets say I have both pins ori and used dash,why can't adapt with VCdS
    I usually put in 25 used dash pin,then adaptation channel 50 to merge used dash with ecu,and after all I reprogram iri keys. In this case not going so,in channel 50 after I put ori pin instead to show on top ori VINetc shows "function not ok"
    On sec bloc you put old power class from edc16 ?
  3. #1518
    brend's Avatar
    Oct 2015
    Same where
    Hi.
    Have enybody experience vw t5 2014 Year DSG transmission km reset with smok (VW0008 DSG CAN OBD2).
    Have enybody done this job?
    Transmission type is DSG DQ500-7f
  4. #1519
    Mar 2011
    EU
    I already tried on T5, but don't remember year and model of DSG, smok set 0km on some place but not all (don't remember group).
    regards
  5. The Following User Says Thank You to Ocin For This Useful Post:
    brend (1st February, 2019)
  6. #1520
    Jan 2009
    MED17.5.1 vw touran 0261 201 355
    03c 906 032 E
    Read on table by CAN not goes , see image
    Any helps, same problem I hAD with edc16 once
    Edit: I once already asked from same ecu and get answer tnx
  7. #1521
    cokolo's Avatar
    Oct 2010
    Springfield :-)
    Smile
    Quote Originally Posted by brend View Post
    Hi.
    In DQ500 you must install DSG filter in getaway module not possible rest over OBD
  8. The Following User Says Thank You to cokolo For This Useful Post:
  9. #1522
    brend's Avatar
    Oct 2015
    Same where
    Thanks!.........
    Quote Originally Posted by cokolo View Post
  10. #1523
    Feb 2019
    have Magic Dash XCan, but can only read no write, not sure why this is? Do you have any advice on this? I bought from Original Smok.com.pl but no support on this
    Will read the KM and unlock the dash no problem, but cannot write.
    This is for an Audi A4 2009 B8 Model, 8K0920900
    If you have latest version of the XCan software can you please send to me? I cannot find it on SmokFTP anymore.
    Thank you very much.
  11. #1524
    Mar 2011
    EU
    you tried on another model ? does it work ? witch error do you have when writting new mileage ? perhaps you choose wrong model.
  12. #1525
    Feb 2019
    Quote Originally Posted by Ocin View Post
    you tried on another model ? does it work ? perhaps you choose wrong model.
    works on another 2009 a4 model, except this one is CVT and the other is STronic
  13. #1526
    samux's Avatar
    Oct 2017
    does smok add option frm repair?
    If I helped, dont forget use buttons reputation+thanks
  14. #1527
    ION CRISTI's Avatar
    ROMANIA
    resolder micronas if the dash dead its vdo and solve the problem
  15. #1528
    soxten's Avatar
    Mar 2013
    Smoke can adapt a used ABS on Volvo cars
    I have done some test here ON BENCH, connected ABS+CEM+ECU and push ”identify”
    Smoke finds all 3 unit with info,key,vin etc.
    And then I have only ”resete code” as highlight buttom.
    If I push that it say something like ”resete ok”
    And after I dont know HOW to adapt abs?
    I cant do anything more...
    Please tell me, ABS seriel number is stored in ECU and if you change ABS tou need to write new seriel number to ecu?
    But now to the big problem, many abs control units have same number on hardware, but diffrent software.
    And I cant find a way to read Eeprom and Flash by obd(?)
    To clone abs you need to do both files.
    If I open it up I can read Eeprom but not special ATE TMS 980 mcu...
    Does any know a way to read this mcu?
    Please need help to find a solution for this.
  16. #1529
    Sep 2015
    03c 906 032 E
    It doesn't work for 99% of ecu edc16 and edc17. I HOPE smok will fix that
  17. #1530
    Mar 2015
    hello
    i have Dacia Logan MCV 2017 with Bosch 0265956560 ABS
    it is possible make KM ??
    i have your full vesrion UHDS but no options
    or connection from back side and some dump tool ?
