cokolo (7th February, 2019)
hello
i have Dacia Logan MCV 2017 with Bosch 0265956560 ABS
it is possible make KM ??
i have your full vesrion UHDS but no options
or connection from back side and some dump tool ?
BSI Siemens Kline
P206 2001, I read pin,eep but can't program key. I did with PPS,and key ok
After some time costumer call and say smelt like smoke in BSI, Normally not from DIAG ONLY, but this is second car , once was C3, both cars key lost, used smok to program key and after that (less than hour) smok in bsi
Hope nothing wrong with smok, maybe just bad luck
Clio 4 2013.... Km changed with block option. Now trip and consumption does not work.... Any solution except doing abs millage without block synchro?
SMOK can not do SEAT EXEO 2008+ BOSCH RB8.
Tell me who knows please if SMOK can write ECU meliage in Ford. :-)
I don`t wont to buy X-Tool for this.
Hi I am thinking of buying SMOK JTAG full .promotion e980 http://smok.com.pl/index.php?id_prod...duct&id_lang=2 any one know if everything works as supposed to and is it good value thanks in advance scoot
Need to replace edc16cp04 ecu on audi Q7 2008y
Ori shows cheksum error, I read all immo data from ori and used ecu. Need to go where car is, so will it works on car procedure like let's say golf6 with edc17? Immo4 I guess should perform after wrote ori data to donor ecu,is it?
Tnx
Solved
CAN Analyser
Are there instructions on how to use the CAN Analyser?
I want to know how to use it properly. For instance I tried the Save Config option but it seems to save the same data no matter what car I'm at.
Presume I'm doing something wrong.
Anyone guide me on this?
Pager.
i have problem with 9df changing mileage
i have read eeprom with programmer but smok recognize this software as unknow version.
here eeprom, i need 2000km and i can test immediatly solution
Can someone tell me step by step w204/w212 mileage change without CAN blocker?
1. Go in ZGW and press block ezs sync?
Should I first read for beckup flash+eep or will read when oress ezs block sync(not wanna read twice flash)
How time it takes,do I need battery charger?
2. Now change in dash?
Tnx
