Page 170 of 171 FirstFirst ... 70120160165166167168169170171 LastLast
Results 2,536 to 2,550 of 2560
  1. #2536
    Oct 2010
    Quote Originally Posted by duzi View Post
    W/R language Only P3..
    912DG128 write Full Flash
    Where can one find or buy such a flash database for the various Volvo P2 models. Like S60, 80/ XC70, 90 /V70. It would be nice if the database is by HW ID or Part No, because what UHDS gives as HW ID and Part No I can't see it written on the label of the board itself. Here see the pictures:
  2. #2537
    Dec 2014
    Lithuania
    I have many (flash + ee) but only signed :Model, Year..
    This was always enough
  3. The Following User Says Thank You to duzi For This Useful Post:
    ngt5 (6th January, 2024)
  4. #2538
    Jun 2012
    hello everyone I have a problem with w205 12-2015
    nec 70F3525 A205 900 34 18
    without following the steps to modify km
    with UHDS
    without keeping eeprom and scn
    I made virgin
    the dash turns on but nothing works
    diagnosis: dash not configured and driving authorization
    I read d-flash and p-flash with jtaG
    any help will be appreciated
    thank you
  5. #2539
    Jun 2012
    Quote Originally Posted by tatagaram View Post
    with UHDS
    I made virgin
    thank you
    solved .......
  6. #2540
    Jan 2017
    Ukraine
    Hello! Does not erase the crash in the Subaru 98221AN12A block. Maybe I'm doing it wrong? Thank you!
    After ^clear^
  7. #2541
    Feb 2021
    Magnitogorsk
    Hi to all!
    I have two IC without PINs.
    5J0920940C from 16.04.07
    and
    5J0920940B from 25.11.10
    Please, help me to extract pins from dumps.
    Both files in attached file
  8. #2542
    Sep 2018
    hi,
    solution from smok for psa delphi by obd works? I try on peugeot and have problems.
    I remove cluster, make bsi obd, put cluster back and old mileage is back.
    next try i remove cluster , done 20 km ride, put cluster and old mileage back.
    next try i remove cluster, done bsi nad for try i disconnect and connect battery and mileage in bsi back
    any ideas?
  9. #2543
    Aug 2023
    Quote Originally Posted by micost View Post
    hi,
    any ideas?
    what year and model is it ? and I take it you're changing the mileage on the cluster on the bench
  10. #2544
    Sep 2018
    3308 2017. yes i put too second cluster wit lower mil, and nothing still same. Show on dash this from bsi, i open cluster and nothing change, its same like was in spare cluster
  11. #2545
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Bsi not being set to 0 correctly maybe need to remove and do eeprom via wire soldering
  12. #2546
    Sep 2018
    so the conclusion is this that uhds dont work correctly with this bsi, i try to wtite to mr smok but his answer was very evasive
  13. #2547
    Aug 2023
    I have never had a problem with BSI on this car , cluster sometimes on later ones but the dump tool works for the cluster if it cant be done by cluster/diag connecter then take a part and read eeprom , Dump tool for bsi also works perfectly ... one way or another smok should do this car
  14. #2548
    Sep 2018
    ok,but you make bsi by obd or by dump?
    i never have problem like this, for me should be easy job it isnt and i little bit dont understand where is problem.
    Dash from anothe car cannot have mileage from donor, so when was changed in bsi and we put second cluster wit lower mileage its should be possible to see original one
  15. #2549
    Ireland
    Skoda Octavia A5 2014
    Part no: 5E0920931
    SW: 5297
    HW: EV_DashBoardJCIMQBAB
    D70F3525 2MB
    May someone has backup flash for it?
  16. #2550
    Good evening,I need bsi configuration file for Peugeot 308 with Delphi bsi and ECU edc17c60 with manual transmission and electric windows. Has someone a similar file please?
