Boils me , smok released an update and all I see is idiots moaning it don't do this and that, if it didn't do the world don't buy it , wait till your stupid Chucky clone adds it ,and then you can charge 40euro per car , as for it been cloned already shut up you bell , cloned in under 3 hours cannot see it , just a thread full of idiots with little to say buy nag nag
rant over ❤️
All about the Bass
I think you are wrong, as everything in life there are few ways for the same thing:
- 1st way: remove the Nec, etc
- 2nd way: as smok does, use the correct skey, access tacho, then you donīt need erase anything to add a key or whatever you want
As I said, first public tool.
About avdi and others, yeah, thinking the same.
Best regards
yugo45 (14th September, 2017)
It Works, today i tested in all key lost situation jetta 2016
yes you need precharge key but not dealer with a simple tp08 it works like jetta 2012 and 2013
-A klass w169 dash mileage not work write km, sw says ok, dash reset but old mileage still on lcd
- Phaeton 2005 and 2013 works ok as touareg, first K line second CAN
wbr
Ziko did you fit a blocker ??
Tools owned.
AVDI commander.
Dashfixer orig.
Dashfixer clone.
Fiat km tool.
Opel km tool.
Ford KM tool.
Op--com colne.
Lexia & PP clone.
Smok PSA, volvo & ford
If someone helps you DONT FORGET TO SAY THANKS its only polite....
And on a side note ive done quite a few of the newer vag cars with smok tool in past few days
yes when it was first released it had bugs as does most software
but with help from smarty a few hours later he released an update that fixed it.
all singing n dancing now
go see your nearest reseller
dave
Tools owned.
AVDI commander.
Dashfixer orig.
Dashfixer clone.
Fiat km tool.
Opel km tool.
Ford KM tool.
Op--com colne.
Lexia & PP clone.
rob h (17th September, 2017)
HELLO GUYS
ANY TESTED FORD EDGE 2012 SPORT WITH SMOK?
Audi A6 2007 edc16c34 need to swup ecu
Pn bench EDC16 CAN ADV I readed ori ecu data, then readed donnor ecu data and write data from ori (CS,PIN,VIN...)
Then put donor ecu in car go to immo4 and pin from car, LOGIN and give me error.. same on immo3
What wrong I'm doing?
Tnx
p.s. as I see after bench operations MAC1 on donor ecu still remain as it, not put mac1 from ori ecu
Power class was wrong, I put good PC but still MAC1 remain from donor ecu (I do this on bench)
If they are from the same car ( I mean same engine capacity ) . Just read - write eprom.
It will start at first turn. Tested mate.
