I read data from ECU by can connection, change data by OBD
amigokola (5th October, 2016)
Hi guys any body try to read with jtag psa airbag uPD70F3624?
im getting this message on screen/screen shot jtag pic.jpg
Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
Have someone tried to read immo data EDC17C74 from mk7 Golf or B8 Passat??
Pcr2.1 is possible to read by smoke and avdi, must unlock it before reading.
To write you need to connect dash+pcr2.1 by can on bench and then adapt.
(It change 1 byte in mac2 in dash when you write cs/pin in pcr2.1 that is why dash must be connected by can)
I see on dash screen after programming pcr2.1 that I dont have "immo" text in screen, only "key missing" then its ok.
On EDC17 I dont know if you need dash connected to ecu when write new cs/pin to donnor/used EDC17(?)
Skickat fr?n min iPhone med Tapatalk
Have you got problems with downloading PCR files from FTP ?? It show 364 fils found. Start downloading but nothing happens.. Maybe it is downloading in background and I am not to patient ??
Yes I have. I earase pc5 files but cant download...
So you had problems to Lupu ?? It must show download process in menu file by file or when it download all it will show all files in program files pcr 2.1 files ?
amigokola (17th October, 2016)
Med 17.5.5 work good read on bench and write on OBD
rojhat (30th September, 2019)
im getting a lot of conflicting info
will smok do a 2015 Renault traffic edc17 km by obd??
