Page 92 of 171 FirstFirst ... 42828788899091929394959697102142 ... LastLast
Results 1,366 to 1,380 of 2560
  1. #1366
    toutougsmserver's Avatar
    Jan 2013
    inside map
    smok uhds last version 3.4.1.2 after update firmware,opel ecu bosch dsg16 not read pin code, error at 50% OF reading eeprom
    but for mileage edit or VIN write all ok
    this hapen only after update firmware to last version
    tested in 3 ecu same problem same error in same adress of reading
    pin readed fast with other tool
    hope smok team repair this bug in coming update
    bcz i am using only uhds for opel, now must go to other man to get other box for reading
    can post screen shot or give other details if needed
  2. #1367
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    NEW problem in Smok
    open license VW0030 SIMOS PCR 2.1 Read PIN + CS ... who has experience ??
    it works ??
    Tested unlock eep ok
    ... but the big problem, Read Ecu ID ..... from " error Read " !!! as in photo attached
    I saw video and read instructions, I changed PC, I started SW as administrator, always present problem.
    ..Ecu Repair ... Steering Wheel Repair ... Dash Repair ... AirBag Repair .... that Bad LiFe ...
  3. #1368
    Faraday's Avatar
    May 2012
    The dark side of the moon
    Did many pcr2.1 no problem
  4. #1369
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    Quote Originally Posted by Faraday View Post
    Do not understand where the problem is! assistance responds after hours ... or does not answer !!
    today try another unit !! desperate
  5. #1370
    Faraday's Avatar
    May 2012
    Do not shout this is not kindergarten. USE good quality power supply 5A min.
  6. #1371
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    Do not shout
    I use good quality power supply 5A min, I also connected ecu in the car, always error! Open sw as an " Admin" ... changed pc ecc ..
    Scream because you see, post #1358, I opened two license Renualt ABS, and tried to work 2 cars, and also generate error here!
    so this week in Smok paid 140+140+320 ... and I did not find any solutions.
  7. #1372
    Quote Originally Posted by centrohifi View Post
    my car 2016 !
    for 2016 car use old license,
    alo tested work good,
    reflash dash and set km ok
  8. #1373
    brend's Avatar
    Oct 2015
    Same where
    Volkswagen Toureg 2012 ....
    Obd2 away
    15 sec. and job done.......
  9. The Following User Says Thank You to brend For This Useful Post:
    yugo45 (28th October, 2018)
  10. #1374
    Jan 2013
    inside map
    Quote Originally Posted by toutougsmserver View Post
    Reading ECU PSG16 Kline
    Licence Accepted
    ECU Response Ok
    VIN: W0L0XCFXXXXXXXXX
    Security Access not ready !!!
    Security Access Error !!!
    progess 50%
    Error at adr: 0025A0
    Read Error
    Finish Read Error
    what about my report for psg16 reading pin code
    no one from support taked care about
    its a bug in last version
    many emails sent to smok support
    no one answer
    Licence Accepted
    ECU Response Ok
    progess 50%
    Read Error
    Finish Read Error
  11. #1375
    no one answer
    Licence Accepted
    ECU Response Ok
    progess 50%
    Read Error
    Finish Read Error
    word on the forum is that smok a excellent seller is but not in support!
  12. #1376
    sasy90's Avatar
    Italy
    Hi, to all somebody have a feedback on smok protocol RT0021 --Renault kadjar, megane iv, talisman, scenic, espace by obd...i buy it only for it because enigma don't work on these cars...
  13. #1377
    esse's Avatar
    france
    I have it (RT0021)and now work very well
    I test it on Mégane and scenic
  14. #1378
    castin's Avatar
    Oct 2015
    Somebody test Traffic 2013 ABS km read/write?
  15. #1379
    didi_du_93000's Avatar
    France Paris
    Anyone have same thinks than me...
    I have bought a FULL PSA option (PTP3) 1 year ago,
    And now when i ask about bought a update to remain in FULL PSA he say ma MUST pay additionnal activation at normal price.
    They don't have same possibility then AVDI and update version from old to new.
    http://www.abrites.com/shop/updated-...nctions-prices
    It's big problem because for now if i update my PSA FULL (PTP3) with new activations released till now they cost me more expensive than bought a new FULL PSA ((PTP3)).
  16. The Following User Says Thank You to didi_du_93000 For This Useful Post:
    Weasel3 (19th October, 2018)
  17. #1380
    damih's Avatar
    france
    Hello support from smok is like abrites i have some problem with SIMOS PCR 2.1 Read PIN + CS support tell me read manuel
    5 star for a support and for me lost money
    if they do like that with a new customer????????
  18. The Following User Says Thank You to damih For This Useful Post:
    centrohifi (6th November, 2018)
