Page 63 of 172 FirstFirst ... 1353585960616263646566676873113163 ... LastLast
Results 931 to 945 of 2575
  1. #931
    Feb 2012
    UPDATE : Maserati change km obd
  2. #932
    Nef's Avatar
    Feb 2017
    Nantes , France
    I'm encountering a problem with my SMOK UHDS. I've full version.
    When I try to do a PCR2.1 adaptation, it always fails ! I've bugged 3 pcr2.1 and no one answers my emails in your company.
    Unlock = OK , Prepare = OK but each time I click on "Read Immo Data", your software tells me "Prepare ECU first"... but it's always prepared.... Just a clue, As I do the unlock operation, power supply consumption is unstable.
    Three tries with 3 differents ecus (different both hw and software) and problem is same
    I've sent to you my logs. PLease give me an answer.
  3. The Following User Says Thank You to Nef For This Useful Post:
    lush29 (14th November, 2017)
  4. #933
    didi_du_93000's Avatar
    France Paris
    If you search support...
    Stop dreaming!!!!
    No support from the support ghost team of SMOK.
  5. #934
    I have always got a Mail back within 1 or 2 days, and fixes were implemented for real Problems within a week.
    So i can´t say that about SMOK-Support.
  6. #935
    Faraday's Avatar
    May 2012
    The dark side of the moon
    Quote Originally Posted by Nef View Post
    First of all you need, as been told many times, good stable power supply. I did few PCR2.1 and never had problem. Just stick with help file in UHDS and go step after step.
  7. The Following 2 Users Say Thank You to Faraday For This Useful Post:
    amigokola (15th November, 2017), yugo45 (15th November, 2017)
  8. #936
    Oct 2015
    Hello
    Smok work fine in Audi A3 2009 by OBD?
  9. #937
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by Mozart1 View Post
    Hello
    Yes .
  10. The Following User Says Thank You to teerak2uk For This Useful Post:
    Mozart1 (15th November, 2017)
  11. #938
    Jan 2016
    Dont worry when dash is dead during immodata read in Micronas.
    Just push "repair flash" button hehe
    First time it took shit out of me
    Hello
  12. #939
    Jan 2016
    1.Can I do Simos7PP (Octavia II BSE) adaptation with SMOK ??
    2.Adaptation can only be done when IMMO is ON ??
    I see only Simos10 but maybe it does it when I select some other ECU ??
  13. #940
    honingkoning's Avatar
    Dessert
    Guys How good is the vw MQB option, How is coverage.
    Pls post What is tested and and What is the result.
    Wbr Adam.
  14. #941
    Top Poster ISIV's Avatar
    Feb 2013
    Somewhere in the univers
    Anyone know how to read w203 ezs with hc08 1j35d with smok jtag for mileage read??I connect like in manual but it doesnt read it....The mcu for keys i read no problem..thanks
  15. #942
    lush29's Avatar
    Oct 2015
    Quote Originally Posted by honingkoning View Post
    Wbr Adam.
    They were the first in the world to released...I don’t think will find better then them yet...
  16. #943
    Jan 2009
    Any time I tried edc16 vag immo write, I get error:
    Write Immo Data EDC16 ...
    Licence Accepted
    Init Ok
    ID1: 03G906016FM 6179HF"R4
    ID2: _#BPG-810 10.08.05 12345678 1
    ID3: WVWZZZ1KZ6W0xxxxx VWZ7Z0E25
    ID4: VWZ7Z0E250xxxx BPG-81010.08.
    ID5: P0101U85B6
    Orginal ECU Data:
    CS OLD : 4026C97A3F27
    PIN OLD : 01369
    Power Class : 3B
    New ECU Data:
    CS NEW : 441D0F206B71
    PIN NEW : 08670
    VIN NEW : WVWZZZ1KZ7P00xxxx
    IMMO ID NEW : VWZ7Z0D061xxxx
    Power Class NEW :
    CS [6..11] NEW :
    Request Challenge Refused
    Pin Request Level 5 Ok
    Security Access I Ok
    Data Changed Error 3B !!!
    Write Error!!!
  17. #944
    Apr 2016
    uk
    Hi dk
    I need advice about smok full..
    I need it most for key programming but can't find much info about key programming on their website.
    Is it good for keys or just for pin codes,dashboard etc..
    Inviato dal mio HTC One utilizzando Tapatalk
  18. #945
    Hi dk
    as I understand it, smok is good for original keys
