Injector codes are OK, pin in plug the same...
I scaned it with CLIP and there are't DTC's.
After write original eeprom car start.
This software error.
[QUOTE=rokibar;3516036]i had this problem at c3 from 2014 read pinfrom bsi and key programing.. pin readed with function read pin by can 2000-2016 success. key added with lexia. my seller ask about it in smok and they told maybe problems in usb or laptop but it is not true. my devices work at another models well.
I have same issue with 2010 C3 today, read pin ok, learn key error.
Lexia code key without any issue.
Renault Scenic 3 (2013) abs new km obd2 away done well?
10 min and job done.......
Was it full obd ?
tried to set a new mileage in Ducato 2014 year before lift via module ft009 by obd?
Regard
Wysłane z mojego SM-G973F przy użyciu Tapatalka
Renault master year 2018 possible ????
Need i do dash only ...or must i do abs ????
hello. i have buied smok. how install usb drivers on windows 10 ? i have installed the file setup.exe, but when connect uhds, usb not recognized.
please help me.
Anyone can give me feed back on Mercedes W463 (G Class) 2014-2015 models .
I need go up with km , so Can filter will not need , Just need to know how good is By OBD?
what licence for renault kangoo with this cluster
