No had mine open and was ok
Put a new usb connector on mine last week it did the same but was fine have a look at the board when plugged into usb there should be a blue light on the board if not send it back
hi did anyone tested Ford FIGO 2017 Yet with SMOK . i have x-tool it works till 2015
but please can anyone confirm in smok it is working in 2016-2017+ models ?
http://smok.com.pl/index.php?id_prod...duct&id_lang=2
W117 Mercedes CLA + 2 can filter ... test
solution? work??
I have installer canfilter in dashboard and in EZS,
read in OBD i KM .. ok
but, do not modify, " Unlocked memory error !!"
you have info ??
THK
..Ecu Repair ... Steering Wheel Repair ... Dash Repair ... AirBag Repair .... that Bad LiFe ...
Hi Guys.
Anyone had luck with Megane 2015?
Will it work?
Thnx!
I had C4 Picasso 2012, BSI done OBD... How to make dashboard? Obd does not work...
i have test smok for new car vag nec24c64 up 2014 no work
in caddy 2014
q3 2015
tigune 2015
yugo45 (14th October, 2017)
VW Passat CC sw0905 kept failing security when trying to read S-Key
Sent from my SM-G950F using Tapatalk
Passat cc has immo in the cluster ?
Maibe bcm .
amigokola (15th October, 2017)
