Page 46 of 171 FirstFirst ... 3641424344454647484950515696146 ... LastLast
Results 676 to 690 of 2560
  1. #676
    Nov 2009
    This does not matter at all
    It is important to know what it can do
    bcm2 elv adapt online offline -echange immodata -clone immodata sinchro bcm elv medc17 edc17 Crafter EZS e EDC17 sinchro -DPF/ EGR/ DTC/ removal/: IMMO ADAPT edc16 EDC17 edc17c64 C74 NOW WORKING MED17/MEV17/ VAG ecu clone full working all
    PCR2.1 FULL CLONE ou adapt, clone all edc17 me17 , etc / dash echange immodata repair immodata add key etc etc
  2. #677
    esse's Avatar
    Jan 2010
    france
    Hello,
    megane III vdo, kill dash when flashing ABS
    The meter does not switch on
    replacement of the meter and all OK
  3. The Following 2 Users Say Thank You to esse For This Useful Post:
    koyot (21st June, 2017), Nicolas9 (27th June, 2017)
  4. #678
    Quote Originally Posted by amigokola View Post
    You choose wrong flash file for sure. I made the same mistake when I did my first PCR SEAT to VW.
    eventually got this - guess i was using wrong flash file...but another strange problem with comfort module...if battery is disconnected the module loses vin etc, i then need to write the original dump back to it so that it works again????????
    surely this is not normal, i tried with another module, same issue?????????
  5. #679
    yugo45's Avatar
    Apr 2010
    Quote Originally Posted by djollie View Post
    I do not think Passat and Seat do not have same Power class. If power class do not match , it will not work.
    Always use same part number form same model, then no problem ever.
  6. #680
    Nicolas9's Avatar
    Feb 2017
    Aruba
    Quote Originally Posted by esse View Post
    Hello,
    which year of birth?
    (apparently it comes back to life when you make eeprom 24c16 back to original)
  7. #681
    cokolo's Avatar
    Oct 2010
    Springfield :-)
    Hello,
    Dont need to buy new or used cluster just writing flash from backup and everything is OK , I have same situation two times and everything is OK with Smok never kill dash when flashing but with Dp4 2 - 3 times .
    ps. From my experience
  8. The Following 3 Users Say Thank You to cokolo For This Useful Post:
    esse (5th July, 2017), rokibar (29th June, 2017), ziko (28th June, 2017)
  9. #682
    Quote Originally Posted by pierre renault View Post
    Anyone else have this problem?
    Good day, Clio 4 dashboard and Renault Trafic 4, before it worked well, today I do update and now does not function v 3.2.1.8 sample information (TTaskDialog requires Windows Vista or later), I have xp and always worked well, now with uptime does not work . Help please
    I have same fault today, used my other pc with windows 7 and it worked fine.
  10. #683
    esse's Avatar
    Jan 2010
    france
    Quote Originally Posted by Nicolas9 View Post
    Hello
    Year 2014
    For eeprom i ll test
  11. #684
    esse's Avatar
    Jan 2010
    france
    Quote Originally Posted by cokolo View Post
    Ok but how writing back up?
  12. #685
    cokolo's Avatar
    Oct 2010
    Springfield :-)
    Smile
    By OBD of course or you can use Jtag BDM if you have or other programmers
  13. The Following User Says Thank You to cokolo For This Useful Post:
    rokibar (30th June, 2017)
  14. #686
    esse's Avatar
    Jan 2010
    france
    By obd no
    Now no com with Dashboard
    Or can you explain me how do
  15. #687
    cokolo's Avatar
    Oct 2010
    Springfield :-)
    By obd no
    Don't look with diagnosis communication just with Smok Multi UHDS load backup your flash and press write and your dashboard it will be back to live.
  16. #688
    esse's Avatar
    Jan 2010
    france
    Ok i ll try and report
    Thank you
  17. #689
    Mar 2014
    Today i tried peugeot 308 from 2014, but smok cant do it, said bsi prog error.
    Anyone tried that option?
  18. #690
    Oct 2015
    Since the last update the bsi Valeo don't work in 2014 cars , it work before
