teerak2uk (15th October, 2017)
Hi experience with this vehicle, protocol MS0005 work?
W117 Mercedes CLA
W176 Class A
W246 Class B
W166 Class M
W463 Class G
test solution? work??
ThK
..Ecu Repair ... Steering Wheel Repair ... Dash Repair ... AirBag Repair .... that Bad LiFe ...
W117 Mercedes CLA : tested and works
tested and workstested and workstested and works
yugo45 (20th October, 2017)
dacia ph2 after 2013 and CLIP V156 and reprog ......and after reprog in engine ecu will be 0 km
first, try programed by obd,
3 of 4 cars , it works
my experience
first try to change the value for a moment, then install can filter. and reprogram the value
works on 3 out of 4 cars
my experience
.first try to change the value for a moment, then install can filter. and reprogram the value
Opel Corsa C with DELCO 1,7 D ecu, i read eeprom and copy to donor ecu but IMMO is ON.
there are differences in the EE
Is cloning not possible ?
offsystem (22nd October, 2017)
Hi, Apologies if this is not right place to post.
New UHDS user. I have Peugeot 307 2006 with Johnson Controls no crypto. Plug in UHDS, told to program BSI only (no dash) by sales, new mileage appears on display, but after 10 mins old mileage reappears.
Sales say my BSI has been tampered with, but very unlikely. Say I must use eeprom tools to modify dash and UHDS for BSI, but if my car has NEC processor forget it...
Could someone please advise the correct procedure for P307 2005->?
Should I use the C4 Dash tool in UHDS?
I have dumps of the EE and Flash if useful prior to being modified if anyone is able to assist as to why UHDS doesnt work?
I did try Set block synchro as well but also did not work...
Zedd
(ps - ignore communication error in the log file - i forgot to turn on ignition once )
Normally bsi obd cluster manually
