From info you shared only advice is to change tuner........
Hi All, Long storey short.
Ecu was previously remapped (before I purchased the vehicle) and smokes quite bad at WOT but file is encrypted from tuner.
Managed to read file with DBM100.
Received a tuned file (egr off and slightly de tuned) which flashed ok but car wont start and get dsg and brake faults on instruments. VCDS reports bad comms with ECU. Reflashed original and alls well.
Tuner removed the noread tag and sent the repaired file back with factory map. This works fine on the vehicle.
This repaired file was then resubmitted but the received tuned file has still the same faults. Tuner has had no issues with other vehicle running this map.
Advised to have factory flash using ODIS then to resubmit to clear any EVC or BDM2GO tags... as the bdm100 is not able to do this.
Unsure why the repaired file works and the tuned one not..
Don't want to through money at the stealers if I'm going to end up in the same boat !
any advice welcome..
Guided fault finding = Feature that many factory scan-tools have and real technician despise it.
Thanks for the reply Gavra,
Is there no truth in the advise given by the tuner ?
anybody able to anything with the file ? would upload if I new how to...
Put your .BIN file in .RAR archive and you can add attachment from advanced menu.
Here you go...
hope they have attached ok..
Original tuned.rarrepaired noread stock.rarFaulty Tuned.rar
That's all I can help. Hereon DK there are many tuners with much more knowledge then I have so you will have to wait for them to check your file.
hot2trot (7th August, 2016)
