dragon100 (9th August, 2016)
I have here in my shop BMW E60 2008 with Airbag ECU 65.77 9172018-01.
Car went flat battery and since the radio don?t work and the Airbag light is ON.
I made diagnostic and Airbag has error 93D7 - ECU Internal Error.
Car is here, so I can try many files...
Someone has a solution for this ??
Inside is eeprom 95128. File is attached.
Your cleared file.
Best regards.
Dragon
aqua_life (9th August, 2016)
If the file doesn't work you must change big capacitor
I need help with e60 535i us, 2007, airbag modul also with:
Internal fault 93d7,
65.77 9145400-01,
ACSM 220 4431 - 05,
eprom 95128 in attachment,
Some sollution?
