Page 79 of 85 FirstFirst ... 29697475767778798081828384 ... LastLast
Results 1,171 to 1,185 of 1264
Thread: X-Prog M
  1. #1171
    Quote Originally Posted by michalez View Post
    xprog-m can read only 95320 so it is the same memory?
    95320 = 25320 ???
    I think you can read 95 series eproms vice versa with 25 series .
    Datasheet 95320 & 25320 show me same pin config .
  2. #1172
    95320 = 25320 ???
    yes.....95320 = 25320
  3. #1173
    Quote Originally Posted by magdex View Post
    I bought Ne X-Prog M V5.3 with Dongle And don't Work !
    V5.0 working ok but soft v5.3 When I try read device still hang on ( Initialising buffer.. ) and nothing ! V5.0 Working OK ..
    Where is Problem .
    Face the same problem.
    Has someone resolve this issue?
    Or just send the device back to China?
  4. #1174
    DK Veteran andrym3's Avatar
    Default Where is Problem
    Where is Problem .
    look it after "Where is"
  5. #1175
    Dongle problem !!!
    Buy another dongle
  6. #1176
    Where is Problem .
    The problem solved.
    Try to install soft following the instuction on the atteched CD on the clean WinXP SP3. I guess, the problem was in soft 5.0 installed before. Remove it before installing v5.3!!
  7. #1177
    jarripote's Avatar
    95320 = 25320 ???
    Friends, are the same, different manufacturer: 95320 (ST) and 25320 by Atmel
    Best regards
  8. #1178
    DK Veteran maybach_'s Avatar
    EU
    Hey guys does anyone know if X-prog can read 29fxxx grateful for answers!
    Be allways Thankfull!
  9. #1179
    Oct 2010
    Quote Originally Posted by maybach_ View Post
    No, Xprogm can't read flash memory.
  10. #1180
    Aug 2011
    but it can do BDM. if your flash is in ECU and MPU is suported by Xprog you could try reading flash
  11. #1181
    But ecu with BDM (EDC16..) havenot 29Fxxx. This old ecu, like EDC15, have not BDM connector. EDC with MPC have BDM , and this have not 29Fxxx. For 29F bust have OBD programmer, or elnec,wellon...... flash programmers.
  12. #1182
    May 2012
    Has anybody tried to register clone?
    Third party XPROG registration fee
  13. #1183
    radsky's Avatar
    May 2012
    Earth
    hello,
    one of my xprog-m died yestaday... I have a dump for atmega64 but I haven`t cfg file to program atmega by another xprog.
    I`m looking for cfg file. Anybody help?
  14. #1184
    here you go
  15. #1185
    bearheroes's Avatar
    Dec 2011
    Does anyone know if the soldering pinouts of rosfar work for Xprog?For example for Mini dash,or CAS3 etc?
