to conform 100% read bcm eprom and post the dump
if you do have launch it work 100% to open lock bcm or immo with correct pincode
Here is my "entrance module" dump
Could someone unlock the module by changing the eeprom dump?
I don't have Launch 431, I only have fvdi and consult 3 without the activation card for NATS functions.
So I can read/write eeprom and use consult 3 for diagnostic and fvdi to try make new key but the pin code is always not accepted.
I hope you can help please
Hello
I need pin code
Primera P12
made in mexico
5wk4 8043a 20734a
No second number !!
ok
i find
4175
hey guys i need some help....so am from trinidad and my car recently was flooded out... its a nissan versa 2008..so i changed all the modules in the car except for the brain cuz it didnt get wet...and was responding to the x-431...here is the problem i changed the bcm (powerlocks weren't working and the x431 want pocking it up)however the one i got was apparently from a version of my car that has a chip and key set ...mines doesn't this i found out way after wards :-( so heres where i messed up...i initialised the nats system on the bcm and now the brain is in lock mode even when i replaced the bcm with another ...ended up gettin getting a friends brain borrowed and the car starts...so is there anyway to unlock my original brain to get it working
scv_15409958806817800549778317148730.jpgswap the chip from original to donor bcm
Hi need pin for a Primera p12,
Your code is 1631
Try and report
Your code is 1631
Try and report
hello need pin code from nats on nissan xtrail,any help?please..i will atach picture..
5WK4 802A G51957A
28590 C9902
MADE IN MEXICO
359A
CAN 2671032209
FCC ID KR5STEP5-6
MCW 129/9511/1998
099
REF 5WK48643/8644
NISSAN STEP 5/5.6
134KHZ
97RI-000005
I-00 0282
..........1021...........
cutiutza (16th November, 2018)
