ip /dcc woes - Page 4
Page 4 of 4 FirstFirst 1234
Results 46 to 49 of 49
Thread: ip /dcc woes
  1. #46
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    pmsl I must have been taking ages to type that you replied above
  2. #47
    V.I.P. Member benny/9's Avatar
    Nov 2008
    north west uk
    i have had this problem with my duo2, and found it happens with certain images
    the vix v4.0 and 4.1 wont connect also the pkt images need the password setting to
    pkteam to get connection,this happens with other images as well, also if you use any
    of the back up images they usual have the password changed . main stream images
    like bh, open bh, open pli work ok. you can also use the computer to transfer to your box
    click start>then computer> next network on the left side of the window and you will see your
    sat box> click on it and two folders appear> click the configuration folder and you will see all
    your box files that you see with the DCC.
    Please Read Carefully!
    No Sky UK NDS Videoguard Hacking Discussions.
    Viewing Pay TV without a valid subscription is illegal
    the files available are kept for experimental & educational purpose only
    original vu duo2 /vu zero/ tm-nano-se. v-box / 36v /1.2 dish,
  3. The Following 2 Users Say Thank You to benny/9 For This Useful Post:
    DOUGALMCD (26th August, 2016), scub (26th August, 2016)
  4. #48
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    He's all sorted now. Did a run through filezilla with him.
  5. The Following User Says Thank You to DOUGALMCD For This Useful Post:
  6. #49
    Aug 2016
    yes all fixed now . filezilla & some good help saved the day .
    thanks y'all !
  7. The Following User Says Thank You to scub For This Useful Post:
    DOUGALMCD (27th August, 2016)
