Results 1 to 8 of 8
    Member Dj dee's Avatar
    Nov 2008
    Default ZGM H2.H - KEEPS GOING OFF - HELP HELP HELP
    Hey DK peeps..
    Issues, issues with ZGEMMA H2.H.
    Keeps going off.
    Help help help folks
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    What do you mean, going off?
    Does the box reboot? displaying 00-100
    Does the box just stop displaying a picture but still show the time on the front?
    Are you doing anything at the time when it goes off ie changing channels
    What firmware/backup image are you using ie openatv, openvix or backup image ie wooshbuild, sucmensee or martin035 backup image
  3. The Following User Says Thank You to martin035 For This Useful Post:
    P&D (17th August, 2016)
    Nov 2008
    Quote Originally Posted by martin035 View Post
    I meant channels ain't showing apart from the free ones..
    It's been down for hours now..
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Reset router and zgemma, if still not working email your magician , but seriously that all that can be said on this subject without breaking the forum rules
    DK Veteran lincsat's Avatar
    Jun 2008
    And remember the magic bit can usually only be used on a single box. Sounds like you may have it on 2 boxes and the 2nd is blocking the 1st.
  7. The Following User Says Thank You to lincsat For This Useful Post:
    martin035 (17th August, 2016)
  8. #6
    Nov 2008
    Default KEEPS GOING OFF - AGAIN..LOL
    Quote Originally Posted by lincsat View Post
    When rebooted, comes back on for less than 10 seconds then off again and won't get back on.
    Just wondered if anyone has had this issues before?
  9. #7
    Jun 2008
    It sounds like the bit that can't be discussed on the forum. Either 2 boxes with the same magic bit, problem at the magic end or, most likely, problem with your configuration
  10. #8
    Sep 2008
    you could ask if box loses its connection to internet,network test from network setup.
