Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 52
  1. #31
    rideon's Avatar
    RO
    So.. what did 'jeep fiat in italy' told 'dealer in spain' to tell you??
    A failure will not appear till a unit has passed final inspection
  2. The Following 2 Users Say Thank You to rideon For This Useful Post:
    chakahafed (4th September, 2016), Meat-Head (29th August, 2016)
  3. #32
    rideon's Avatar
    RO
    Wondering if raining tonight.....
  4. The Following 2 Users Say Thank You to rideon For This Useful Post:
    chakahafed (4th September, 2016), Meat-Head (4th September, 2016)
  5. #33
    chakahafed's Avatar
    nouakchott
    I have an appointment with them on September 12
    Envoy? de mon SM-G928C en utilisant Tapatalk
  6. The Following 2 Users Say Thank You to chakahafed For This Useful Post:
    Meat-Head (4th September, 2016), rideon (4th September, 2016)
  7. #34
    Meat-Head's Avatar
    Quote Originally Posted by chakahafed View Post
    wants to be quicker than that, spanking new car, dk member, 0 downloads etc
  8. The Following User Says Thank You to Meat-Head For This Useful Post:
    chakahafed (6th September, 2016)
  9. #35
    rideon's Avatar
    RO
    September 12...
    They sure take their time on this...
    19th August was your first post on the subject...
    Almost a month... what can i say,at least keeps the mileage low,good resale value...
  10. The Following 2 Users Say Thank You to rideon For This Useful Post:
    chakahafed (6th September, 2016), Meat-Head (6th September, 2016)
  11. #36
    chakahafed's Avatar
    nouakchott
    If we got no answer we will ship the car to dealer in Spain. We have no choice..
  12. The Following 2 Users Say Thank You to chakahafed For This Useful Post:
    Meat-Head (6th September, 2016), rideon (6th September, 2016)
  13. #37
    Meat-Head's Avatar
    SUMMARY:-
    Vechile fitted with "AdBlue" which is pig pish & distilled water, which is extra
    weight, to lower exhaust emmissions, despite being a SPANKING NEW, car it has to be low loaded because it
    wont start to a differant country!
    Thats really going to help the enviroment!
  14. The Following User Says Thank You to Meat-Head For This Useful Post:
    chakahafed (7th September, 2016)
  15. #38
    rideon's Avatar
    RO
    Just wondering, did Spain dealer fix it ?
  16. The Following User Says Thank You to rideon For This Useful Post:
    Meat-Head (28th September, 2016)
  17. #39
    Oct 2013
    Did someone temper with the mileage???
    Anyway. You need to reset the SCR DEF Tank Fluid Level with your witech.
    double check the exhaust gas temperature sensor(s) including scanner readings.
    Engine computer may stop the engine if reading is bad.
  18. #40
    Mar 2009
    An update will be greatly appreciated
  19. #41
    chakahafed's Avatar
    nouakchott
    We sent the car to the dealer in morroco they fix it. But i dont know how..
  20. The Following 2 Users Say Thank You to chakahafed For This Useful Post:
    bonecrusher (7th August, 2017), Meat-Head (6th January, 2017)
  21. #42
    Mar 2017
    USA
    Just as a side note, if the oil change is due it will suspend regeneration.
  22. #43
    rideon's Avatar
    RO
    Since you already dug up this old thread,regeneration got nothing to do with scr...
  23. #44
    Mar 2017
    USA
    Ya I added this as a side note for this owner, a lot of owners do not realize it. This guy must of had some other code that popped up that he erased, once that p241d code is set, it will not reset that timer until it sees a good trip for the dtc that set the timer into countdown. Or if the ecm is reflashed... If he has a witech pod he can go under miscellaneous tab in ecu and select scr extended mileage with active fault routine which will give you an additional 50 miles of driving. But you are correct, regeneration has nothing to do with scr....
  24. The Following User Says Thank You to circ1977 For This Useful Post:
    rideon (4th August, 2017)
  25. #45
    andfonte's Avatar
    Aug 2015
    Could you send me the VIN code of the car so I can try to help you?
    If I help you in any way, please use the magic buttons ( + reputation and thank you )
    No Report , No Thank = No Help
    Sincerely, Anderson
