Results 1 to 12 of 12
    Jan 2016
    Default X-Prog vs X-Prog m for Micronas.
    Hi Guys.
    I want to buy ori X-Prog mostly for Micronas. Which is better? One from TMT or Eldab ?? Regards.
    Jan 2016
    I was thinking about SMOK Jtag to but I dont know if it has good coverage in Micronas and if it can read whole flash or only Sec Block ??
    Maartinj's Avatar
    Nov 2010
    Poland
    X-prog for Micronas is old shoool ...
    rob h's Avatar
    May 2011
    I have tried 2 with xprog clone 551, i used all options. and recomended and proven connections.
    What when wrong? I do not know.
    So i am now considering a alternative tool like:
    250 Programmer for VW & AUDI
    Item No. SM35
    Manufacturer: YH-YANHUA TECH
    R250 Dashboard Programmer for Vag VW Audi
    Item No. SK36
    Audi VW micronas and Fujitsu programmer 2.0
  5. The Following User Says Thank You to rob h For This Useful Post:
    amigokola (25th August, 2016)
  6. #5
    micromax's Avatar
    Dec 2009
    South Poland
    xprog from eldb work ok, with new adapter ADP0017 - old adapter (and china cloned) not work.
    smok tool also is good for this job.
  7. The Following 2 Users Say Thank You to micromax For This Useful Post:
    amigokola (25th August, 2016), rob h (23rd August, 2016)
  8. #6
    Jan 2016
    Quote Originally Posted by micromax View Post
    But Smok reads whole flash of Micronas or only sec block to swap dash ??
  9. #7
    Jan 2016
    Quote Originally Posted by Maartinj View Post
    What in this case do You sugest Martinj ??
  10. #8
    Mario3's Avatar
    Dec 2014
    smok can only read, not write
  11. The Following 2 Users Say Thank You to Mario3 For This Useful Post:
    amigokola (29th August, 2016), rob h (25th August, 2016)
  12. #9
    rob h's Avatar
    May 2011
    Reading is ennough for me, cs and pin is all i need.
  13. #10
    Jan 2016
    But if you corrupt flash....
  14. #11
    Maartinj's Avatar
    Nov 2010
    Poland
    Quote Originally Posted by amigokola View Post
    no need to read whole flash to play with that type of cluster .
    Proper tool will do most you want over OBD
  15. The Following User Says Thank You to Maartinj For This Useful Post:
  16. #12
    micromax's Avatar
    Dec 2009
    South Poland
    sometimes we need change flash, change language etc.....
    need read and write flash. some micronas have rom, not flash , and we can only read this area.
    i always use xprog from eldb.
  17. The Following User Says Thank You to micromax For This Useful Post:
