    digicon's Avatar
    Default TM5402Hd M3 and TM-F3/5 New Patches
    Patches in Download section for these 2 models
    5402 M3 & TM-F3/5
    Big Update that these 2 new models can now open Tandberg Channels with appropriate Keys, Feeds on 7? east and 10? east at the weekend for games at 3pm in HD as well as other satellites
    taken from TM many thanks
    The first 5 entries in Tandberg cas are for Arena Sports on 39e so leave alone
    When entering tandberg you need to enter the 4 IDENT digits then keys, heres example183C 01 12 34 56 78 12 34 56 78
    You will select a Tandberg CAS slot
    Enter 183C in IDent
    Enter 12 34 56 78 12 34 56 78 in Line 01 (Key), if no line 01 create one by editing line number 00 to 01
    So this is what you should see
    CAS - TANDBERG
    IDENT - 183C
    00 00 00 00 00 00 00 00 00
    Please note the above is just an example
  2. The Following User Says Thank You to digicon For This Useful Post:
    den1 (24th August, 2016)
  3. #2
    kidderminster
    By the look of it, the CAS MENU has got the keys built in on line 118 to 149, will have to amend line as and when.
    DEN
    digicon's Avatar
    The first 5 entries are assigned to Arena Sports on 39? east, the rest you can alter at will
    Sep 2013
    Default Tangberg T101
    Ok then, when Tangberg comes up with keys then, they give you the Ident of T101 then the keys.
    But How do you put the T101 Ident in the Technomate M3 Satellite receiver, as you cannot put a T in the Ident system, it only goes from A to F.
    Barryeagle1
    5402 M3 & TM-F3/5
    Sep 2013
    Tandberg T101
    Ok then, when Tandberg comes up with keys then, they give you the Ident of T101 then the keys.
    Barryeagle1
    kidderminster
    Some other Tandberg idents come up as follows T 6B2 , you put into the receiver as 06B2 . For T101 you put as 0101.
    The codes which you may find may not clear, they are working to get the patch to work (you will get sound but no picture.
    Hope this helps.
