Results 1 to 7 of 7
    Default FORD TRANSIT BODY
    need read body ford transit 2007 mcu 4L91N i try to read with upa tell error try with x prog 5.50
    pin 23,40,42,42,46 extal but not succes
    can you help me with achematic how can i conect
    any solution for read this mcu
    pls
    SOOLEVED,,,,,,,,,,,,,,
    DK Veteran bobbik's Avatar
    EUROPE
    So, would U explain us how you did it? I tried with Upa and Xprog , and also without any success. Upa nor Xprog has not this mask in their device list. Upa (geniune) i tried as "DG256" and Xprog (chinese) as "Hcs12 eeprom"
    i cant read this in table but with AVDI OBD change vin prog in car end car start ok
  6. The Following User Says Thank You to gogoli For This Useful Post:
    bobbik (2nd October, 2017)
    koolstuff's Avatar
    Nov 2015
    Dakar (Senegal)
    do you have the pinout for this bcm? i have the same here with 4L00M but can't find anywhere the pinout
    EUROPE
    Look at the picture in post #1 There are soldering points similar to those from old focus and mondeo dashboards. Use multimeter an you'll find pinout
