Page 1 of 2 12 LastLast
Results 1 to 15 of 22
    sergei5005's Avatar
    Nov 2012
    Bs As
    Default Diagbox cleaner need !!! THANKSSSSS
    Hi friends . Someone have Diagbox cleaner ???? Need unistall and re-instal diagbox. THANKSSSSSSSS !!!!!!!!!!!!!
  2. The Following User Says Thank You to sergei5005 For This Useful Post:
    willymakit100 (13th November, 2018)
  3. #2
    Aug 2010
    Sao Paulo, Brazil
    Never saw such a thing, just uninstall through windows manager, clear the folders, clear the registry and you're good to go. Did that in the past when had a bad installation and worked fine.
  4. The Following 2 Users Say Thank You to phophollety For This Useful Post:
    psabad (12th September, 2018), sergei5005 (13th September, 2016)
  5. #3
    electronistul21's Avatar
    Nov 2011
    galati,romania
    Default diagbobox unistaler
    try this.i use with succes.
    Carprog 8.21,xprog 5.55,galletto v54,kess and ktag rework
  6. The Following 42 Users Say Thank You to electronistul21 For This Useful Post:
    adrianoo (1st February, 2023), alle bmw (28th April, 2017), Ampul (11th November, 2018), AndyCZ (23rd November, 2021), atamata (23rd January, 2017), attyk (18th September, 2016), benyy (19th June, 2018), brane0001 (2nd December, 2019), cart10 (6th August, 2017), Col19 (31st October, 2019), costa sys (25th July, 2021), datapage (18th September, 2016), dikoval (19th June, 2023), dinana (30th November, 2017), djalil (7th August, 2018), djdanny (3rd September, 2017), dupisa (20th June, 2017), dusan.stevovic (2nd December, 2017), elektro1991 (10th May, 2021), kronk92 (13th October, 2016), laxon (9th September, 2023), MANGAESY (23rd December, 2023), Mario6 (26th May, 2022), mesrine_29 (22nd June, 2017), metercar (27th May, 2022), miha99 (19th September, 2016), nicolas2015 (11th October, 2017), okm (28th November, 2018), prodlt (17th July, 2020), psabad (12th September, 2018), qwertdaro (12th May, 2017), RafaelMix (6th May, 2023), russell (6th November, 2022), s.a.n.c.a (30th December, 2018), sarigol45 (27th June, 2019), sergei5005 (20th September, 2016), thboxx (3rd May, 2020), titoun (6th October, 2016), tomt82 (10th October, 2016), Wsergik (8th October, 2023), xpgs (19th April, 2017)
  7. #4
    Oct 2016
    Does it work in windows 7?
    i can't reinstall diagbox without error
  8. #5
    super jumbe's Avatar
    Dec 2008
    Livingstone
    Cleaner got Trogen Horse ....
  9. The Following User Says Thank You to super jumbe For This Useful Post:
    A630V (29th July, 2018)
  10. #6
    Aug 2016
    muchas gracias
  11. The Following User Says Thank You to dardoelectro For This Useful Post:
  12. #7
    Apr 2017
    Greece
    Can you try this one>?
  13. The Following 20 Users Say Thank You to Stelaras For This Useful Post:
    Ampul (11th November, 2018), benyy (19th June, 2018), brane0001 (2nd December, 2019), Col19 (31st October, 2019), costa sys (25th July, 2021), dinana (30th November, 2017), djdanny (3rd September, 2017), dupisa (20th June, 2017), line44 (25th July, 2021), MARIKO (24th May, 2019), nicolas2015 (11th October, 2017), okm (28th November, 2018), prodlt (17th July, 2020), rodriguez9548 (18th July, 2022), sarigol45 (27th June, 2019), Silver740 (25th April, 2020), tobyb (24th May, 2019), WhoAmI (27th September, 2020), Wsergik (8th October, 2023), zeno666 (2nd July, 2021)
  14. #8
    Jun 2010
    gracias por el cleanup
  15. #9
    Top Poster Group MB Best's Avatar
    Nov 2012
    electronistul21 and Stelaras
    it is work good in win7
    Regards
    Must be cooperation between us
  16. The Following 2 Users Say Thank You to Group MB Best For This Useful Post:
    electronistul21 (3rd October, 2017), Stelaras (28th July, 2017)
  17. #10
    Mar 2017
    I have this batch script, don't know if it works, never had to use it.
    @echo off
    echo ATENCION!!!!!!!!
    echo Este script borra Diagbox completamente del sistema (ideal para realizar instalaciones "limpias")
    echo.
    set /p r=Esta seguro de querer continuar? (S/N)
    if '%r%' equ 's' goto borrar
    if '%r%' equ 'S' goto borrar
    exit
    :borrar
    echo.
    echo ####### Descargando DiagBox de memoria...
    start "" /wait /b net stop FirebirdGuardianDefaultInstance > nul 2> nul
    start "" /wait /b net stop FirebirdServerDefaultInstance > nul 2> nul
    start "" /wait /b net stop ftspssrv > nul 2> nul
    if exist C:\APP\ddc\bin\psaLance.exe C:\APP\ddc\bin\psaLance.exe -stop
    taskkill /T /F /IM sim.exe > nul 2> nul
    taskkill /T /F /IM eclipse.exe > nul 2> nul
    taskkill /T /F /IM psaagent.exe > nul 2> nul
    taskkill /T /F /IM diagnostic.exe > nul 2> nul
    taskkill /T /F /IM AWFInterpreter_vc80.exe > nul 2> nul
    taskkill /T /F /IM WSTransformer.exe > nul 2> nul
    taskkill /T /F /IM MCComm.exe > nul 2> nul
    taskkill /T /F /IM AWRSrv.exe > nul 2> nul
    taskkill /T /F /IM AWACSserver.exe > nul 2> nul
    taskkill /T /F /IM psalance.exe > nul 2> nul
    echo.
    echo ####### Quitando servicios...
    sc delete FirebirdGuardianDefaultInstance > nul 2> nul
    sc delete ftspssrv > nul 2> nul
    echo.
    echo ####### Quitando drivers...
    call :GetOEM ACTIA Automotive
    if "%GetOEM%" neq "ERROR" pnputil -f -d %GetOEM% > nul 2> nul
    call :GetOEM FabulaTech
    echo.
    echo ####### Quitando valores del registro...
    reg delete HKLM\SOFTWARE\DiagBox /f > nul 2> nul
    reg delete HKLM\SOFTWARE\ACTIA /f > nul 2> nul
    reg delete HKLM\SOFTWARE\POUD /f > nul 2> nul
    reg delete HKLM\SOFTWARE\FabulaTech /f > nul 2> nul
    set KEY=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion \Uninstall
    reg delete "%KEY%\DiagBox Update V7.02 to V7.06 V7.06" /f > nul 2> nul
    reg delete "%KEY%\DiagBox Update V7.06 to V7.07 V7.07" /f > nul 2> nul
    reg delete "%KEY%\DiagBox Update V7.11 to V7.16 V7" /f > nul 2> nul
    reg delete "%KEY%\DiagBox Update V7.16 to V7.24 V7" /f > nul 2> nul
    set KEY=HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID
    reg delete "%KEY%\{CFCCB454-80CF-481f-B50A-29112EBB0F85}" /f > nul 2> nul
    reg delete "%KEY%\{0C5C1E33-9887-4AED-9648-38573CBBD335}" /f > nul 2> nul
    reg delete "%KEY%\{0D3C6990-1AFE-49BA-B17A-AF1E65D22F08}" /f > nul 2> nul
    reg delete "%KEY%\{17301DA3-C84D-11CF-AE6F-0020AF31CEF9}" /f > nul 2> nul
    reg delete "%KEY%\{17301DA4-C84D-11CF-AE6F-0020AF31CEF9}" /f > nul 2> nul
    reg delete "%KEY%\{310FDEA0-B150-11D3-B3F0-00104B726EA8}" /f > nul 2> nul
    reg delete "%KEY%\{310FDEA1-B150-11D3-B3F0-00104B726EA8}" /f > nul 2> nul
    reg delete "%KEY%\{310FDEA2-B150-11D3-B3F0-00104B726EA8}" /f > nul 2> nul
    reg delete "%KEY%\{310FDEA3-B150-11D3-B3F0-00104B726EA8}" /f > nul 2> nul
    reg delete "%KEY%\{310FDEA4-B150-11D3-B3F0-00104B726EA8}" /f > nul 2> nul
    reg delete "%KEY%\{316408A0-41E5-11D0-A547-0020AF1E73B9}" /f > nul 2> nul
    reg delete "%KEY%\{316408A1-41E5-11D0-A547-0020AF1E73B9}" /f > nul 2> nul
    reg delete "%KEY%\{316408A2-41E5-11D0-A547-0020AF1E73B9}" /f > nul 2> nul
    reg delete "%KEY%\{316408A3-41E5-11D0-A547-0020AF1E73B9}" /f > nul 2> nul
    reg delete "%KEY%\{316408A4-41E5-11D0-A547-0020AF1E73B9}" /f > nul 2> nul
    reg delete "%KEY%\{316408A5-41E5-11D0-A547-0020AF1E73B9}" /f > nul 2> nul
    reg delete "%KEY%\{316408A6-41E5-11D0-A547-0020AF1E73B9}" /f > nul 2> nul
    reg delete "%KEY%\{316408A7-41E5-11D0-A547-0020AF1E73B9}" /f > nul 2> nul
    reg delete "%KEY%\{316408A8-41E5-11D0-A547-0020AF1E73B9}" /f > nul 2> nul
    reg delete "%KEY%\{316408A9-41E5-11D0-A547-0020AF1E73B9}" /f > nul 2> nul
    reg delete "%KEY%\{316408AA-41E5-11D0-A547-0020AF1E73B9}" /f > nul 2> nul
    reg delete "%KEY%\{316408AB-41E5-11D0-A547-0020AF1E73B9}" /f > nul 2> nul
    reg delete "%KEY%\{316408AC-41E5-11D0-A547-0020AF1E73B9}" /f > nul 2> nul
    reg delete "%KEY%\{316408AD-41E5-11D0-A547-0020AF1E73B9}" /f > nul 2> nul
    reg delete "%KEY%\{316408AE-41E5-11D0-A547-0020AF1E73B9}" /f > nul 2> nul
    reg delete "%KEY%\{316408AF-41E5-11D0-A547-0020AF1E73B9}" /f > nul 2> nul
    reg delete "%KEY%\{316408B0-41E5-11D0-A547-0020AF1E73B9}" /f > nul 2> nul
    reg delete "%KEY%\{316408B8-41E5-11D0-A547-0020AF1E73B9}" /f > nul 2> nul
    reg delete "%KEY%\{436F92DF-27A4-49EE-9EBF-D8F8102BAB38}" /f > nul 2> nul
    reg delete "%KEY%\{592301E0-2EF7-11CF-A543-0020AF1E73B9}" /f > nul 2> nul
    reg delete "%KEY%\{5B789B81-E46E-11CF-AE6F-0020AF31CEF9}" /f > nul 2> nul
    reg delete "%KEY%\{5F00C9ED-006F-4141-B552-4D019B787C87}" /f > nul 2> nul
    reg delete "%KEY%\{72CEB250-CB2D-11D1-B3A7-006097B77FF4}" /f > nul 2> nul
    reg delete "%KEY%\{72CEB251-CB2D-11D1-B3A7-006097B77FF4}" /f > nul 2> nul
    reg delete "%KEY%\{72CEB252-CB2D-11D1-B3A7-006097B77FF4}" /f > nul 2> nul
    reg delete "%KEY%\{84F29E28-9976-4286-8521-3E1B1C3189E7}" /f > nul 2> nul
    reg delete "%KEY%\{95F224E0-1366-11CF-AE6E-0020AF31CEF9}" /f > nul 2> nul
    reg delete "%KEY%\{A0027B21-37E5-11D0-A547-0020AF1E73B9}" /f > nul 2> nul
    reg delete "%KEY%\{A0027B23-37E5-11D0-A547-0020AF1E73B9}" /f > nul 2> nul
    reg delete "%KEY%\{A0027B25-37E5-11D0-A547-0020AF1E73B9}" /f > nul 2> nul
    reg delete "%KEY%\{A0027B27-37E5-11D0-A547-0020AF1E73B9}" /f > nul 2> nul
    reg delete "%KEY%\{B0483C2D-CE80-4480-BB23-3708A1D54074}" /f > nul 2> nul
    reg delete "%KEY%\{B68DBFAB-16A0-11CE-80BF-0020AF31CEF9}" /f > nul 2> nul
    reg delete "%KEY%\{C2AA24F0-A9D0-4C19-B740-F33BB4446F4F}" /f > nul 2> nul
    reg delete "%KEY%\{D5912801-7E0B-11D0-809C-00A02454310A}" /f > nul 2> nul
    reg delete "%KEY%\{D940E4BE-6079-11CE-88CB-0020AF6845F6}" /f > nul 2> nul
    reg delete "%KEY%\{D940E4C8-6079-11CE-88CB-0020AF6845F6}" /f > nul 2> nul
    reg delete "%KEY%\{D940E4D2-6079-11CE-88CB-0020AF6845F6}" /f > nul 2> nul
    reg delete "%KEY%\{DC60CED0-603E-11D1-B2E3-006097B77FF5}" /f > nul 2> nul
    reg delete "%KEY%\{E5F37B00-EDF6-11CE-AE6E-0020AF31CEF9}" /f > nul 2> nul
    reg delete "%KEY%\{F7C06880-F9B2-11CE-AE6E-0020AF31CEF9}" /f > nul 2> nul
    reg delete "%KEY%\{F7C06881-F9B2-11CE-AE6E-0020AF31CEF9}" /f > nul 2> nul
    reg delete "HKLM\SOFTWARE\Classes\TypeLib\{D940E4E4-6079-11CE-88CB-0020AF6845F6}" /f > nul 2> nul
    reg delete "HKLM\SOFTWARE\Firebird Project" /f > nul 2> nul
    set KEY=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion \Run
    reg delete "%KEY%" /v ediagStart /f > nul 2> nul
    reg delete "%KEY%" /v psastart /f > nul 2> nul
    reg delete "%KEY%" /v SIM /f > nul 2> nul
    set TEMPPATH=%PATH%
    set TEMPPATH=%TEMPPATH:;C:\AWRoot\bin\common=%
    set TEMPPATH=%TEMPPATH:;C:\AWRoot\bin\lib=%
    set TEMPPATH=%TEMPPATH:;C:\APP\ddc\bin=%
    set TEMPPATH=%TEMPPATH:C:\AWRoot\bin\common;=%
    set TEMPPATH=%TEMPPATH:C:\AWRoot\bin\lib;=%
    set TEMPPATH=%TEMPPATH:C:\APP\ddc\bin;=%
    reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\Environment" /v Path /t REG_EXPAND_SZ /f /d "%TEMPPATH%" > nul 2> nul
    echo.
    echo ####### Borrando archivos...
    if exist "%ProgramFiles%\DiagBox" rd /s /q "%ProgramFiles%\DiagBox" > nul
    if exist "%ProgramFiles(x86)%\DiagBox" rd /s /q "%ProgramFiles(x86)%\DiagBox" > nul
    if exist c:\ACTIA rd /s /q c:\ACTIA > nul
    if exist c:\APP rd /s /q c:\APP > nul
    if exist c:\APPLIC rd /s /q c:\APPLIC > nul
    if exist c:\AWRoot rd /s /q c:\AWRoot > nul
    if exist c:\Backup_DB rd /s /q c:\Backup_DB > nul
    echo.
    echo Proceso finalizado.
    pause
    exit
    :GetOEM
    if not defined GetOEM set GetOEM=%*
    set GetOEM_tmp=%GetOEM%
    for /F "tokens=2 delims=:" %%a in ('pnputil -e') do for /F "tokens=*" %%b in ("%%a") do (
    if "%%b" equ "%GetOEM_tmp%" (
    goto GetOEM_seguir
    ) else (
    set "GetOEM=%%b"
    :GetOEM_seguir
    if "%GetOEM%" equ "Microsoft Windows Hardware Compatibility Publisher" set GetOEM=ERROR
    goto :eof
    Before running it you probably need to stop all services and processes with this:
    @echo off
  18. The Following User Says Thank You to wokcz For This Useful Post:
    mejis (31st March, 2022)
  19. #11
    Nov 2017
    Is this cleaner for all versions of Diagbox?
    Quote Originally Posted by electronistul21 View Post
  20. #12
    Nov 2017
    Quote Originally Posted by akerolf View Post
    I successfully installed v7.01 without any error. I start to encounter error after updated all the way to v7.06. It prompt MCOMM.exe error every time I start the program
    Any suggestion ?
  21. #13
    Dec 2017
  22. The Following 3 Users Say Thank You to Perryno For This Useful Post:
    pier12 (27th April, 2019), prodlt (17th July, 2020), zeno666 (2nd July, 2021)
  23. #14
    May 2018
    Default diagbox cleaner
    is it working?
  24. #15
    Jun 2010
    Spain
    THANKS THAT`S RIGHT. DO NOT EXECUTEIT ON YOUR COMPUTER
