SIEMENS PPD1.2 03G 906 018 AN Seat Altea 2.0 tdi DPF Removal
Results 1 to 4 of 4
    Default SIEMENS PPD1.2 03G 906 018 AN Seat Altea 2.0 tdi DPF Removal
    Hi folks. I need a DPF removal from my ecu file.
    I have had some problems with car going into limb mode, and the DPF is almost new, all sensors to the filter are new, but still problems.
    Main problem seems to be a temp sensor(g448) on the filter, must drive with the sensor disconnected to avoid limb mode.
    So i am ready to remove DPF and hopefully end up with a car that works.
    this is the file i read from the car with mpps.
    03G906018AN.RAR
    Hope someone can help me out here.
    Sep 2016
    Europa
    Witam sprawdzić i potwierdzić
  3. The Following User Says Thank You to jkubp For This Useful Post:
    creep0 (5th September, 2016)
    It works like a charm. Thanks for saving my head for further headaches.
    Now it is just a hardware remove, and crossed fingers for a trouble free drive from here on out.
    Thanks again jkubp
    Nov 2016
    Hello, do you confirm this is a working solution? Thanks
